Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM Intrinsics Syntax
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sajid Rabbani Avagundam
over 13 years ago
over 13 years ago
Note: This was originally posted on 13th July 2011 at
http://forums.arm.com
Presently we are using few intrinsics as below: (thou they are in macro form!)
#define CP15_CONTROL_READ(x) asm("mrc p15, 0, %0, c1, c0, 0":"=r"(x))
#define CP15_CONTROL_WRITE(x) asm("mcr p15, 0, %0, c1, c0, 0"::"r"(x))
we do not know how to use 'x' type of variables in case of
multiple operands
in intructions like add as mentioned above.
with some exploration in generic linux source code for arm, we derived below macro translation for ADD:
#define ADD2(sum, input1, input2) asm("ADD %2, %0, %1" :"=r"(input1),"=r"(input2) : "r"(sum) : "cc");
however, this does not translate to an 'add' instruction when objdump is generated. help!
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Note: This was originally posted on 14th July 2011 at
we have able to identify the general form of an inline assembler statement:
asm(code : output operand list : input operand list : clobber list);with this, we derived as below for our above example:
#define ADD(sum, input1, input2) asm("add %0, %1, %2" : "=r"(sum) : "r"(input1),"r"(input2))
with this, three operand inline assembly is working fine
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
AFAIK there are usually only intrinsics for instructions that it would be difficult or impossible for a compiler to generate from C code. Such as the accessing control registers, or NEON ops.
The intrinsics which do exist can be found here:
http://infocenter.arm.com/help/topic/com.arm.doc.dui0472c/CHDFGFAB.html
Otherwise you could look at inline or embedded assembler. But you should really think about what you are doing if you need an ADD instruction.
Cancel
Vote up
0
Vote down
Cancel
