Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
printf from assembly
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Avi Levi
over 13 years ago
Note: This was originally posted on 24th June 2011 at
http://forums.arm.com
I am trying to call printf from an assembly code but getting into some difficulties.
I found this post:
How to Call a Function from ARM Assembler
However, when using the printf inside my code I get a linker error:
Error: L6238E: foo.o(.text) contains invalid call from '~PRES8' function to 'REQ8' function foobar
Searched for that as well, and found that I am calling a C function that requires 8-byte stack alignment
from an assembly code that does not preserve 8-bytes. (Hence the ~PRES8 and REQ8)
The article suggested that I should add the PRESERVE8 directive before my AREA directive:
add the PRESERVE8 directive to the top of each assembler file. For example, change:
AREA Init, CODE, READONLY
to:
PRESERVE8 AREA Init, CODE, READONLY
But when I do that I get an error that says:
Bad symbol 'AREA' not defined or external.
Can anyone please help me figure out how to do it right?
Thank you
Etienne SOBOLE
over 13 years ago
what assembler do you use ?
gcc ?
if you use gcc, write your code in C and then compile it with
gcc -S myfile.c
that will make the assembly code (myfile.s) of your c program.
Then you'll be able to see how the printf work and the syntax will be correct.
Etienne
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
PRESERVE8 is a directive by itself and needs to be on a separate line:
PRESERVE8
When you use the PRESERVE8 you are promising that any time you branch to an IMPORTED symbol you will have changed SP by a multiple of 8 (including 0). See also
http://infocenter.ar...d/Cacehagj.html
Cancel
Vote up
0
Vote down
Cancel
