Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Hard Fault on cortex M3 NXP
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Alessandro Spinetti
over 13 years ago
Note: This was originally posted on 20th June 2011 at
http://forums.arm.com
I've coded a small program to download in a usb memory some data acquired from the LPC1768 Cortex M3.
I use IAR EW to code and J-Link LITE to program/debug the code.
So, when I test my program with debugger connected (either in debug or release mode) it works fine.
When I program the micro and run it without the debugger connected I obtain an Hard Fault exception.
When I check the value of HFSR it return 0x80000000 -> DEBUGEVT = 1 ?
Why? Where is my fault?
Thanks.
Alessandro
Alessandro Spinetti
over 13 years ago
Hy Joseph,
I've searched any occurrence of BKPT instruction, but I haven't found it.
It's not simple to debug, I can only put some strings in 16x2 character lcd. I write to the lcd the DFSR value also and the value is 0x2. Maybe the core is in a debug mode?
Thanks.
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
The most likely issue is that the program has called a function which try to communicate with the debugger.
A breakpoint (BKPT) instruction is executed, and since there is no debugger attached, it went into hardfault instead.
Keil website has an application note about debugging fault exception:
http://www.keil.com/appnotes/docs/apnt_209.asp
Please try to generate a disassemble code of the program image and see if there is any BKPT instruction generated, and trace what function call could have run the BKPT function.
Hope this helps.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
If DFSR is 0x2, it means BKPT instruction executed.
Iin the hardfault handler, you can try output the stacked PC value to your LCD.
http://embdev.net/topic/177024
From the stacked PC value, you should see what instruction the code was running.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
