Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ArmCC Code optimisation
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jude Baby
over 13 years ago
Note: This was originally posted on 1st June 2011 at
http://forums.arm.com
I am trying to generate an assembly code for the following C structure access using armcc
typedef struct
char a : 4 ;
char b : 4 ;
} struct1 ;
Variables a and b are 4bits each
I have the following function
void fun1 (struct * ip)
ip->a = 1 ;
ip->b = 2 ;
The assembly instructions generated for the following code with optimization O2 is as follows
The ARM Compiler / assembler version is 4.1 [build 514]
;;;31 void fun1(struct1 * ip)
;;;31 {
;;;31 ip->a = 1;
0x01004688: e5d01000 .... LDRB r1,[r0,#0]
0x0100468c: e3c1100f .... BIC r1,r1,#0xf
0x01004690: e2811001 .... ADD r1,r1,#1
;;;32 ip->b = 2;
0x01004694: e3c110f0 .... BIC r1,r1,#0xf0
0x01004698: e2811020 ... ADD r1,r1,#0x20
0x0100469c: e5c01000 .... STRB r1,[r0,#0]
;;;33 }
Here fields [3:0] and [7:4] of the register r1 are updated using
4 instructions , 2 BIC and 2 ADD .
Is a compiler optimization possible to further reduce the number of instructions ?
I was hoping that it would further be reduced to 2 instructions as
BIC r1 , r1 , #0xff
ADD r1 , r1 , #0x21
or somthing like
MOV r1 , #21
Regards
Jude
Jude Baby
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Alexander Shirshikov
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
