Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
secure & non-secure address space in Cotex-A9
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
jianhui li
over 13 years ago
Note: This was originally posted on 11th May 2011 at
http://forums.arm.com
Dear professor,
I would like to know how is it implemented the separate address space between secure state and non-secure state in Cotex-A9?
" When implemented, the Security Extensions provide two physical address spaces, a Secure physical address space and a Non-secure physical address space."
this is described in the datasheet of ARMv7.
And I understand that secure and non-secure state has separete translation table according to different TTB registers copy.
but i am confused how do they have separe physical address space?
jianhui li
over 13 years ago
thanks so much for your explanation.
But I am still not very clear about the following question.
if the whole address space is 0 ~ 100, and I want assign 0 ~ 100 to the secure space and 21 ~ 100 to the non-secure space.
how to do this? is this done by HW or SW?
thanks so much!
Cancel
Vote up
0
Vote down
Cancel
jianhui li
over 13 years ago
Note: This was originally posted on 12th May 2011 at
thanks so much.
Yes, I got it.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
This guide may help:
http://infocenter.arm.com/help/topic/com.arm.doc.prd29-genc-009492c/index.html
Iso
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
So far your understanding is correct - the Cortex-A9 sees two physical address spaces: Secure (S) and Non-Secure(NS). This means that when looking at physical address:
S:0x8000 != NS:0x8000
The Security Extensions (TrustZone) defines the processor supports two worlds, effectively you have two virtual processors. Again these are the Secure world and Non-Secure (Normal) world. The Normal world can only access the Non-Secure physical address space. The Secure world can access both the Secure and Non-Secure physical address spaces.
Each world has its own set of page table. So when in the Secure world you will _always_ use the Secure page tables. And when in the Normal world you will _always_ use the Non-Secure page tables. The page table format for the Secure world includes an extra bit - the NS bit. This bit tells the processor whether to translate that block of virtual address space to Secure PA or the Non-Secure PA. That's how the Secure world can access both.
How this looks on the bus?
Well, AXI includes a signal to define whether the address being accessed is Secure or Non-Secure. This is the AxPROT[1] signal. This will get set appropriately by the processor based on the world that generated the requested access, and the page tables.
Now, exactly how the memory system uses this bit is up to the designers. You _could_ use it as an extra address bit. So S:0x8000 goes to a different peripheral to NS:0x8000. More commonly it is just used to gate access. Say you have a memory for "secure" data. Then the memory system simply aborts any non-secure access to that address range.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
The layout of the physical address space is system specific.
Typically a system designed to use TrustZone will have a small amount of memory/peripheral space fixed as being Secure only. With part/most of the rest of the system configurable as Secure or Non-Secure. For the configurable regions, the thing that controls Secure/Non-Secure will be something like a TrustZone Protection Controller or TrustZone Address Space Controller. Basically a peripheral with registers you write to in order to toggle a given peripheral or address range between Secure and Non-Secure accessible. You would have to configure this at boot.
Basically - check the documentation for the board/chip you are using.
NOTE - Many systems have TrustZone capable processors - but not TrustZone aware memory systems. That is the chip designer didn't think the secure stuff was necessary for their intended use case, and therefore didn't include the necessary system support. You'll still be able to use the TrustZone features in the processor, but you won't have the memory system protection.
Cancel
Vote up
0
Vote down
Cancel
