Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cortex-A9 RealMode Memory size
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
gael therond
over 13 years ago
Note: This was originally posted on 29th April 2011 at
http://forums.arm.com
Dear ARM's guru,
I'm asking myself about the ARM real mode and especially about the memory management on this mode.
Is there a limitation on memory allocution in real-mode under ARM?
Is ARM's Cortex CPU behave like Intel's x86 CPU in real-mode in term of memory allocution?
In fact I want to know if I could use more than the usual 1Mb (Using Gate A20 trick) available in real-mode with an Intel CPU.
Many thanks in advance.
gael therond
over 13 years ago
Note: This was originally posted on 30th April 2011 at
Many thanks to your answer sim!
This is exactly the answer I was looking for
I'm currently trying to develop a fast bootloader for my NVidia TEGRA 250 DevKit and as NVidia doesn't provided us the TRM I was not sure about this point.
More I use ARM Processors, more I like it, there are no limitation due to backward compatibility for now, and that a good point on it
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
None of the concepts you mention exist in ARM systems.
Out of reset the memory is 4GB linear and flat mapped; with the MMU enabled, each process still has a 4GB linear address space, however, the operating system can map each 4KB to any physical address.
The answer to your final question appears to be yes, you can [theoretically] use ~4096 times the amount.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
