Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Secondary CPU Boot-Up
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sajid Rabbani Avagundam
over 13 years ago
Note: This was originally posted on 21st April 2011 at
http://forums.arm.com
Environment: ARM-CA9 MultiCore
Pre-condition: Boot monitor starts all the cores together and later continues with primary CPU0, where as the secondary CPU1, CPU2, ... are moved to wait for interrupt condition with WFI instruction.
-------------------- snippet start (secondary CPU wait state)
loop:
wfi
ldr pc, loop
-------------------- snippet end
Question: For primary CPU, later when boot monitor gives control to u-boot software and finally u-boot gives control to application software. In this application context, if the primary CPU wants to wakeup the secondary CPUs, it basically needs to interrupt them, below observations was done:
no interrupt handling was observed by secondary CPUs
but when, above shown snippet was modifed to include a 'nop' instruction after WFI instruction, the secondary CPUs started handling interrupts
I assume that this is because of the way the return from interrupt handling is done, something like LR+4, LR, ... so on.
Please clarify/reason-out why it is working in the later modified condition? Or what is the actual procedure to wake up secondary CPUs using interrupts ...
Martin Weidmann
over 13 years ago
As you're looking at the disassembly, how are you inserting the NOP?
How are you checking whether the interrupt is taken? By breakpointing the IRQ vector, or just by seeing whether any appears to happen?
What does the IRQ handler do? Does it return with the standard sequence (SUBS pc, lr, #4 or equivalent), or to some other address?
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
