Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Flags of APSR Register in Cortex M3
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Muhammad Ahsan
over 13 years ago
Note: This was originally posted on 19th April 2011 at
http://forums.arm.com
Hello all,
I am having probelm in writing Flags of APSR Register in Cortex M3. The result of a comparison cuases the negative flag to get set to 1. Next instruction reads the APSR using MRS instruction. Before executing this instruction I clear the negative flag to 0. If I execute the instruction of reading the APSR after clearing the negative flag, program jumps to hardfault handler. Reference manual states that these flags are writable.
We can write APSR using MSR instruction too. But is it possible to change a single bit(Flag) as I have mentioned above?
Thanks in advance
Muhammad Ahsan
over 13 years ago
Note: This was originally posted on 21st April 2011 at
How do you clear the APSR? By a debugger?
Yes I do so using Debugger. I am using IAR Tool chain and here I have possibility to view all registers including APSR and writable bits can be changed to 0 or 1. There is another T bit in EPSR register which defines ARM mode when written to 0 and for Thumb mode it has to be written to 1. I am not touching this bit at all. All I do it to chnage the state of flag in APSR from 1 to 0 and vice versa. the program hits hardfault exception for all flags no matter the flag is changed from 0 to 1 or 1 to 0.
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 20th April 2011 at
If you write 0 to the xPSR using a debugger (only a guess), you might have accidentally cleared the T bit (Thumb state). This cause a fault exception when you step into the next instruction as it means you are trying to execute an ARM instruction.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
Joseph Yiu
over 13 years ago
Note: This was originally posted on 22nd April 2011 at
I have tested this using Keil MDK with ULINK2 with Cortex-M3 r2p0 but didn't get any problem.
I used a simple test
__asm void test_1(void)
MOVS R0, #0 ; Breakpoint set here, then single step through
MOVS R1, #
SUBS R0, R0, R1 ; Set N flag, then use MDK uVision debug to clear N bit to 0
MRS R0, APSR
BX LR
It might worth checking the value of xPSR before and after the change to see if the debugger change other bits.
Also, when it enter hard fault, please check the values of various fault staus registers.
It might also worth email IAR to see if they are aware of any known problem which might affect this.
I am away next week so won't be able to check the forum until May.
regards,
Joseph
Cancel
Vote up
0
Vote down
Cancel
