Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Concept of Scratch and Preserved Registers
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Muhammad Ahsan
over 13 years ago
I am confused in understanding the difference between scratch and preserved registers. I have read the development guide of IAR Embedded Workbench but the topic was written in such a way that I could not get the real sence of it.
Any help or if possible some example that can help me differenciating between the both will be regarded.
Thanks in advance
Top replies
Martin Weidmann
over 13 years ago
+1
Note: This was originally posted on 5th April 2011 at http://forums.arm.com I've not used IAR's tools, but I'm assuming it follows the AAPCS (Procedure Call Standard for the ARM Architecture). The AAPCS...
Martin Weidmann
over 13 years ago
I've not used IAR's tools, but I'm assuming it follows the AAPCS (Procedure Call Standard for the ARM Architecture). The AAPCS can be summarized as:
r0-r3 - parameter passing, and return value
r4-r11 - protected
r12 - scratch
So what does this mean? Well lets say you have some code like this:
main
BL foo
foo
BX lr
Main() is the caller, and foo() is callee. That is, main() is calling foo(). So the AAPCS rules say that main() must put the arguments to foo() in r0 to r3. It can expect the return value of foo() in r0. It can also assume that when foo() returns r4-r11 will have the same values as they did before the call.
Foo() can assume its arguments are in r0-r3, and it knows it must put its return value in r0. It also knows that it can corrupt r12, using it as a scratch register. For r4-r11, foo() can use these registers - BUT ONLY IF IT RESTORES THE ORIGINAL VALUES BEFORE RETURNING.
Cancel
Vote up
+1
Vote down
Cancel
Martin Weidmann
over 13 years ago
r4-r11 - protected
r12 - scratch
main
BL foo
foo
BX lr
Cancel
Vote up
+1
Vote down
Cancel
