Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
MMU problem on ARM926EJ-S
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Fabu Kosmi
over 13 years ago
Note: This was originally posted on 19th January 2011 at
http://forums.arm.com
Hello community!
I've faced a problem while porting an OKL4 3.0 kernel to an ARM926EJ-S (Samsung S3C2412) board. I'm able to compile my kernel and load it into the boards RAM, but after starting it there is no reaction on my serial output. So I started to debug the source code. Due to the fact that I've got no JTAG and other debugging methods failed I'm using a LED based debugging method. I activate a LED by writing into its register. So I encountered a very early function in code in which the execution flow stucks:
It is a function that enables MMU, caching e.g.. I figured out: if I set the MMU disable bit in it I get out of this function. But if i enable the MMU, the flow stucks. The MMU is a necessary part of the kernel.
Before the MMU gets enabled the code has to perform several code specific operations:
start() must ensure that the platform is set to the following state:
- All caching is disabled.
- Virtual memory is disabled (MMU is turned off).
- Memory controllers are configured and running.
- The stack pointer is set.
- Other control registers required for further initialization are set.
After that the code enables MMU, caching e.g. considering following ARM926EJ-S specific requirements (ARM926EJ-S TM Revision: r0p5 Technical Reference Manual):
1. Program the TTB register (CP15 c2) and the domain access control register (CP15 c3).
2. Program first-level and second-level page tables as required, ensuring that a valid translation table is placed in memory at the location specified by the TTB register.
I could image the (a) problem refers to page table related issues.
Do you have an idea which problems I've to take into account?
Best regards,
Fabu
Fabu Kosmi
over 13 years ago
Note: This was originally posted on 24th January 2011 at
I did that - but unfortunately it doesn't work anyway.
Cancel
Vote up
0
Vote down
Cancel
jameer mulani
over 13 years ago
Note: This was originally posted on 21st January 2011 at
You need to invalidate TLB abd caches.
Cancel
Vote up
0
Vote down
Cancel
