Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
cycle penality before using a register as pointer
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Etienne SOBOLE
over 13 years ago
Note: This was originally posted on 28th January 2011 at
http://forums.arm.com
Hi.
it seem's that you can't use a modified register as a load address directly in the next cycle (with the Cortex A8)
For example
ADD r0, r0, #16
LDR r1,[r0]
will not execute in 2 cycles but in 3 cycles.
I'm looking in the ARM documentation where this penality cycle is explain but I do not find !!!
If I simply use the cortex A8 cycle table:
ADD will write his result in E2
while LDR will need R0 in E1
So If I just apply those rules, the 2 instructions should execute in 2 cycles.
So !!! Does anybody can tell me where this pipeline-dependent latency is explain (or simply notify) ?
Thank's
MayaDirect Marketing Safieddine
over 13 years ago
Note: This was originally posted on 30th January 2011 at
In the 5th example in the trm,
ADD r0, r0, #16
LDR r1,[r0]
I considered that the load will need the register at the beginning of the cycle for address calculation, whereas the add will produce that value of the register (r0) at the end of the cycle. So forwarding is not applicable at the same cycle due to the limited cycle time, and an extra cycle is therefore required at which forwarding will take place.
So am I right or shall we consider the real latency of the ALU and the Address Generating Unit and if they can complete sequentially in the same cycle??
But are you sure that you got 2 cycles when you tested again?
Because if you considered what I said, same logic applies on the other two pieces of codes.
I think here comes the extra cycle!
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
ADD r0, r0, #16
LDR r1,[r0]
Cancel
Vote up
0
Vote down
Cancel
