Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
JUMPING TO A SECOND PROGRAM FROM A BOOT LOADERJUMPING TO A SECOND PROGRAM FROM A BOOT LOADER
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
bandung laiciais
over 13 years ago
Note: This was originally posted on 18th January 2011 at
http://forums.arm.com
I have an application that is separated into two parts that are compiled and linked separately. Part 1 is a "Bootstrap Program", reside in NVRAM in the processor that checks to see if Part 2 "The Application" which is reside in the external flash is present at address 0x3C000000. After execution of Part 1 my program should jump to address 0x3C000000 which is reside in external flash.
How do I do this?
bandung laiciais
over 13 years ago
Note: This was originally posted on 19th January 2011 at
Thanks Sim for the reply, but how about in assemble language because the space in NVRAM very limited and using C consume alot of space. Thanks again
Cancel
Vote up
0
Vote down
Cancel
bandung laiciais
over 13 years ago
thanks sim, i will try it n see how
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
If you're using C, you could try:
void goto_flash(void)
((void(*)(void))0x3C000001)();
Note that the final "1" indicates that the target is in Thumb; if the target is in ARM then this should be changed to "0".
hth
s.
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
LDR r0,=0x3C000001
BX r0
Same caveats about the "1" apply.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
