Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
pipeline result register write.
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Etienne SOBOLE
over 13 years ago
Note: This was originally posted on 13th January 2011 at
http://forums.arm.com
Hi.
I'm trying to develop a small program to count the cycle of a program.
I found an interresting case.
As you know 2 instructions can not execute in the same cycle if the destination registrer is the same.
It's sound logic, but in fact due to pipeline step, this is not as logic at it should be.
For example the next code should work
mov r0, #15
add r0, r0, #15
The MOV will write r0 in E1
The ADD will write r0 in E2
So there is no good reason to not start instruction execution in the same cycle
An opposite case is the next one
mul r0, r1, r2
nop
add r0, r5, r6
add r0, r6, r7
The mul will execute in pipe 0 and write is result in E5
The 2 ADD will execute in separate pipeline 0 and pipeline 1 (due to the same destination regsiter). But they both have to wait for r0.
So finally they will execute exactly in the same cycle and should write their result in the same cycle.
So finally my question (because there is always a question):
What mean
issued
in this sentence
"Instructions with the same destination cannot be issued in the same cycle"
Does it mean the started cycle or the writing result cycle ?
Etienne
MayaDirect Marketing Safieddine
over 13 years ago
Note: This was originally posted on 29th January 2011 at
hello Etienne
sorry for replying late but i was so busy the last period
finally i got answers for our questions
as for my previous reply, i discovered that the scoreboard in the decode pipeline checks for RAW hazards only and not WAW hazards.
However, the issue logic includes cross checking of the instructions to be dual issued. The cross checking allows detection of RAW and WAW hazards between the two instructions. Note that RAW hazards are always evaluated in terms of when needed and when available.
If the cross checking provided that RAW or WAW hazard occurs: dual issue will NOT occur, and this what happened in the 1st example where two cycles were required. then why is it so when dest reg can be available before E5? this is because instructions should commit in order to ensure avoiding WAW hazards among instructions and to handle exceptions correctly. So the two instructions if issued together, will be writing into the same register together: not allowed (through adding any logic for prioritization) by cortex A8
And answering my qstn: it turned to be that all instructions will write-back into the register file in E5.
(yes my info is from an official document about the cortex
no assumptions unless stated
and by the way in your first post,be careful that the add will not wait for mult to write in E5 . this is because a new instruction with a RAW hazard with an older one can issue (get into the Execute pipeline) as soon as the req reg is available by forwarding.
So issuing is sending instructions out from decode pipeline into execute pipeline
Regards
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
hello Etienne
Regards
Cancel
Vote up
0
Vote down
Cancel
