Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
"Real" ARM instructions generated by the assembler
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
The Prof
over 13 years ago
Note: This was originally posted on 2nd December 2010 at
http://forums.arm.com
Not 100% sure this is the right place to post a question like this but...
I'm tasked with a simple question of setting bit 11 of R2 to 1 and bits 10 & 12 to 0. This was accomplished in these 2 instructions:
ORR R2,R2, #&800
BIC R2,R2, #1400
I'm now asked:
"Work out the real ARM instructions generated by the assembler in your answer to Q4. You may express these instructions as assembler, but they must use the precise value of C, and an appropriate rotate."
I thought I just did some real assembly language? What does the assembler do here? What's this nonsense about C?
Arn't instructions generally:
Op, Rd, Rn, shift C
Also am I right in thinking you can only perform a even ror and rol (that is you cannot have ror #3 , but you can have lsr #3??)
Gilead Kutnick
over 13 years ago
My guess is that they want to know the immediate base and rotate values. If in doubt I'd generate full machine code in annotated hex describing each of the fields. I don't know what they mean by "C" either.
The restriction you're thinking of actually applies to immediates - there are only four bits for the rotate, so it's an 8-bit value rotated by an even number from 0 to 30. This is done so it can roughly span the entire 32-bit space.
Cancel
Vote up
0
Vote down
Cancel
Gilead Kutnick
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
