Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM Instructions Viewer
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jolie Eid
over 13 years ago
Note: This was originally posted on 26th October 2010 at
http://forums.arm.com
Hello
I was wondering what software program can help me translate a C/C++ code program to the corresponding set of ARM instructions. I DO care about browsing the ARM instructions.
Does RVDS4.1 serve this purpose, or it doesn't enable viewing the instructions? and any idea about the unsupported features of RVDS 4.1 evaluation product?
Thanks in advance
Jolie
Jolie Eid
over 13 years ago
Note: This was originally posted on 27th October 2010 at
Thank you!!
Cancel
Vote up
0
Vote down
Cancel
Jolie Eid
over 13 years ago
Note: This was originally posted on 29th October 2010 at
Hello, I didn't try this thing because it seems you are talking about some command window. However i'm using now RVDS4.1 along with the supported workbench.
Do you have any idea if the set of instructions viewed in the "Disassembly" tab of my_code.o is subset of ARM ISA instructions, or is it of the ISA my computer implements?
Also, what does the my_code.s includes? No such file was shown in the "Project Explorer" of the RVDS workbench.
I am still new in this domain, so sorry if my questions are sometimes ambiguous or severely simple.
Thanks in advance!
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
When you compile C/C++ files you can tell the compiler to generate an assembler listing as well as an object. Just add "--asm" to the command. For example:
armcc --debug --cpu=ARM926EJ-S -O2 -c --asm my_code.c
Assuming no compile errors, you see my_code.o and my_code.s generated. The my_code.s file has the assembler listing.
You can do pretty much the same thing post compile, or for a complete image, using the fromelf tool. Just run:
fromelf -c my_object.o/my_image.axf
The output gets dumped to the console, so you probably want to re-direct it the a file.
The main difference between the two approaches is the output format. The file generated by the compiler (something.s) can be run through the assembler (armasm) to generate an object. The output of fromelf cannot.
Cancel
Vote up
0
Vote down
Cancel
