Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
maybe, a BUG of ARM Linker version 4.0 Build 697
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
wang david
over 13 years ago
Note: This was originally posted on 12th August 2010 at
http://forums.arm.com
Here is the piece of code in a C source file.
#pragma arm section rwdata ="cellular_ram"
u8 gv_CFI[256]={0};/* MAN ID DID1,DID2,DID3*/
u16 gv_DIDR;
u16 gv_RCR;
u16 gv_BCRInit;
u16 gv_BCR;
then, in scatter file, somethin like this:
ER_PRE_INIT_DATA 0xA01FF000 (0x00001000)
init.ptl(cellular_ram,+FIRST)
drv_gpio.*(+RW,+ZI)
I want to put gv_CFI and the ohter 4 u16 var together in a fix place.
But, after link finished. I check the MAP file.
I found this:
[color="#FF0000"] gv_CFI 0xa802fe58 Data 128 init.ptl(.bss) [/color]
gv_DIDR 0xa01ff000 Data 2 init.ptl(cellular_ram)
gv_RCR 0xa01ff002 Data 2 init.ptl(cellular_ram)
gv_BCRInit 0xa01ff004 Data 2 init.ptl(cellular_ram)
gv_BCR 0xa01ff006 Data 2 init.ptl(cellular_ram)
the gv_CFI is placed wrong.....
How can I deal with this ? Why the linker split it from the other four? They are all .bss. why??
Who can help me?
I'm downloading the latest build of RVCT. I hope it will resolve my problem. ...
After upgrade to RVCT v4.0 Build 821, the same problem.
Then, I tried like this:
u8 gv_CFI[256]={0xFF};
It's done.
Thanks for the help of scott.
Peter Harris
over 13 years ago
Build 821 has the same prb.
As Scott says, this isn't a problem. It's correct behavior.
The first item is zero-initialized the others are not, so the compiler / linker are free to split them up across different section types.
Indeed, as they are unrelated data items, there is really no guarantee about their relative placement in memory. The compiler would be perfectly correct to place them in totally different sections in different areas of memory (although no sane compiler would).
Then make them fields of a single structure, then the compiler is not allowed to split them up ...
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
