Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Code optimization using ARM instruction
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
promod sinha
over 13 years ago
Note: This was originally posted on 11th August 2010 at
http://forums.arm.com
Hi Friends,
I am currently working on a project to develop an emergency call application using 3gpp specification 26.267 (eCall standard).
For the same using the Qualcom reference stack for eCall (3gpp 26.268). I am using micro controller having ARM9 processor with maximum processing power 104 MHz.
I am facing problem to optimize the Qualcom reference eCall stack code. I receive 320 bytes of PCM frame in every 20 ms. Ideally, I need to process that 320 bytes of data and reply back withing 20 ms to avoid data loss.
But in case distorted/corrupted data is received, 3gpp code goes for CRC check and retransmission. But because of my processor's limited capability, my application is not able to process the incoming PCM frames and reply back within 20 ms; requires 1 second to process the data and reply. Hence, I start loosing data.
I have tried to use ARM/THUMB instruction set and -O2 optimization level for the entire project. But didn't help much in case of CRC check.
Could anyone help me to solve this critical problem ?
Peter Harris
over 13 years ago
Note: This was originally posted on 16th August 2010 at
Unless you find a big mistake it will probably be hard to get a 50:1 reduction.
1 second is 104 million instructions - seems like a lot needed to process a 320-byte packet! Assuming you have a cached processor, have you enabled the instruction and data caches? That would give a large performance boost.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
