Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Issues with loading to neon registers above q7
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Brett Park
over 13 years ago
Note: This was originally posted on 29th June 2010 at
http://forums.arm.com
Have you seen any issues with vld and registers q8-15?
For some reason, doing a load to registers below q8 work fine, but above q8 the registers don't get set.
For example, the first won't work but the second will.
in this case, r3 contains a pointer to a float array (4 floats)
vld1.32 {d16-d17}, [r3]
vld1.32 {d0-d1}, [r3]
any ideas?
Sylvain Gaeremynck
over 13 years ago
Note: This was originally posted on 5th July 2010 at
I have the problem with gdb. But this is a debugger problem (it doesn't refresh the content of registers q7-q15 and d14-d31), not a problem with neon.
You can try to copy data using q7-q15 it should work and prove that there's no problem.
Cancel
Vote up
0
Vote down
Cancel
Sylvain Gaeremynck
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
