Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cycle Measurement for CortexA8 on Beagle Board
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Raghavendra Mallela
over 13 years ago
Note: This was originally posted on 12th May 2010 at
http://forums.arm.com
Hi all,
I'm working on CortexA8 Hardware(Beagle Board). I want to measure the cycles that it takes for my function using the cycle count register that is present in the CP15 coprocessor register. I made total memory into 1MB descriptors, a total of 4096 and set the permissions for each descriptor and enabled the MMU and cache. I'm trying to get the cycles that it takes for my function. But when I'm trying to do this I got more cycles than what I expect.
My function is
void main()
int count1, count2;
//Enabled cycle counter here
count1 = read_ccount(); // That returns the cycles count value from the performance monitor register
func();
count2 = read_ccount(); // That returns the cycles count value from the performance monitor register
TotalCycles = count2 - count1;
.global func
func:
MOV r4, #7
MOV r5, #2
MOV r6, #9
MOV r2, #60000
nextt1:
MUL r7, r5, r4
MUL r4, r6, r6
MUL r9, r5, r6
MUL r7, r6, r5
SUBS r2, r2, #1
MUL r8, r8, r4
MUL r9, r9, r5
BNE nextt1
MOV r0, r8
bx lr
.end
The cycles that I got using cycle count register is 960745. But Manually, if I calculate it should take around 900000 as
6 Mul's * 2 cycles each * 60,000 loop count = 720000
1 sub * 1 cycle each * 60,000 loop count = 60000
1 branch * 2 cycles each * 60,000 loop count = 120000
Total = 900000(appr)
Is the cycles which I'm getting using cycle counter is correct or is I'm missing any thing in calculation. Can any one help in this.
Thanks in advance,
with regards,
Raghavendra.M
Anthony Van Herrewege
over 13 years ago
Note: This was originally posted on 17th May 2010 at
I was wondering how you got 2 cycles for 1 branch, since the Cortex A8 technical reference manual on p. 658 (Section 16-12) states that a branch only takes 1 cycle. If that's the case, the total cycle count should be even less of course, so I'm afraid I can't help with that part.
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
