Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
HELP ! ARM 926 ejs icache and dcache
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Matt Luo
over 13 years ago
Note: This was originally posted on 11th February 2010 at
http://forums.arm.com
The system memory is SDRAM, and NAND booting. MMU enable, allocate low address space for code and read-only data. Hight address space for read-write data. They are all cacheable and bufferable. Code running in the low address space(read only segment) is better than running in the high address space(read-write segment). So , I doubt whether the icache is enable for the hight address space(read-write segment). But, in the datasheet ,there is no description about the icache influence space.
Matt Luo
over 13 years ago
Yes, I am sure. And I have wrote and read the page table entry. The lower address memory is tiny page, and the higher address memory is coarse page. Both are cacheable and bufferable.
Cancel
Vote up
0
Vote down
Cancel
mark nicholson
over 13 years ago
The page table entries control which areas (of the whole 32bit address space) are cacheable. This is usually defined in 1MB blocks. (but can be defined in 4KB blocks in some areas). Are you 100% sure the cacheable attributes are the same for the lower and higher areas of memory you mention?
Cancel
Vote up
0
Vote down
Cancel
mark nicholson
over 13 years ago
Then (unless I'm missing something) code running from either area should use the cache.
Unless of course (for whatever) reason the cache is beign deliberately disabled in one area of your codebase (by writing to CP15 control).
If you have a ARM11 or Cortex device - you could consider using the PMU to measure cache hits when executing code from the different areas.
Cancel
Vote up
0
Vote down
Cancel
