Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Debug build works but release
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Yu Qiao
over 13 years ago
Note: This was originally posted on 19th January 2010 at
http://forums.arm.com
My code works on debug build ( -Otime -g+ )
But release build can't work ( -Otime -O2 -zo )
the code is the same. the compiler is ADS1.2
Do you guys have any idea or previous experience on such an issue?
Thanks.
Simon Craske
over 13 years ago
Presumably changing the "RAM settings" involves writing specific values to specific addresses;
compiling with "-O2 -g+" will have the effect of causing accesses to behave as though volatile, whilst this behaviour will be optimised out with "-O2 -Otime"; for example:
void foo(void)
unsigned char *f = (unsigned char *)0x100;
*f = 2;
*f = 4;
*f = 6;
Generates three write accesses with debug, but only writes "6" without debug enabled.
Declaring f as "volatile unsigned char*", will result in all three writes always being generated.
If you are talking to peripherals, are you sure you're using the volatile specifier correctly?
hth
s.
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
void foo(void)
*f = 2;
*f = 4;
*f = 6;
hth
s.
Cancel
Vote up
0
Vote down
Cancel
