Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Debugging Cortex M3 from external Flash
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Prasad Prasad
over 13 years ago
Note: This was originally posted on 12th January 2010 at
http://forums.arm.com
I am using the STM32F103 controller from ST having the cortex M3 core. My firmware mechanism demands some portion of code to be executed from external Flash memory.
While executing the firmware from external memory I could not put the hard breakpoints.
1. Is this a limitation of Cortex - M3 core or the controller?
2. Can this be overcome by using any other tool then J-Link?
3. If this is a limitation of core the please let me know if you have any suggestions or workarounds.
Thanks,
Prasad
Simon Craske
over 13 years ago
The Cortex-M3 hardware breakpoint unit only functions in the address range 0x0 - 0x1FFFFFFF.
Instruction space above 0x20000000 is typically writable, with breakpoints implemented via software means.
Three options probably exist:
- If possible, relocate your external flash to below 0x20000000,
- alternatively, replace the flash device with a RAM device during debug,
- alternatively, use a PC based watchpoint match to halt.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
hth
s.
Cancel
Vote up
0
Vote down
Cancel
