Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Need help with IAR Embeeded Workbench Linker
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
ckuecker ckuecker
over 13 years ago
Note: This was originally posted on 5th January 2010 at
http://forums.arm.com
I am working with a Luminary LM3S6965 processor in a product that is intended to be firmware-upgradable in the field. We have an Ethernet port that we connect to a server that can use a proprietary protocol to download new firmware. Our product code is divided into two sections, a boot loader that resides at the start of flash, and an application that resides at 0x10000. If the boot loader detects a valid downloaded upgrade, it copies it from an unused area of flash to 0x10000 and erases the downloaded code. The boot loader is self-contained, and after verifying a valid application, jumps into a fixed vector table located at 0x10000. The application takes care of all its' initialization. Interrupt vectors are steered up to the same vector table at 0x10000 and handled in the application. The bootloader does not use any interrupts.
I had the system working originally by building one big program, with the boot loader and application code separated by linker configuration file commands. Unfortunately, the IAR linker does not allow me to reliably keep various parts of the code separated - for instance, the initialization code that should have been for the bootloader gets placed somewhat randomly in the application code, and therefore the vector from the bottom of flash points to the wrong location after we do a firmware upgrade.
I tried to fix this by going to two separate programs, and the IAR debugger disassembly window tells me I have succeeded in getting everything into its' proper place. Unfortunately, the debugger refuses to load the application code and run properly, telling me 'Warning: __vector_table symbol not found." The code runs directly into the fault IRQ handler and hangs.
I had previously loaded the bootloader section of the code into flash using the debugger, exited, and then loaded the application code with the debugger. The bootloader's vector table is still at the start of flash memory, and it appears proper in the disassembler window. The debugger evidently cannot figure out how to start the code correctly.
I tried running the code as a system, without the debugger, and it hangs up, so there's a bug in there for real. I need to get the system running under the IAR debugger to find and fix the problem.
Anyone had a similar situation and lived to tell of it?
ckuecker ckuecker
over 13 years ago
Note: This was originally posted on 6th January 2010 at
Got the linker squared away - but there's a problem in the IAR startup code. The code executes a pop in one of the initialization routines, and the resulting PC is garbage.
I've sent the zip file of the whole project to IAR - they are looking into the issue.
Chuck
Cancel
Vote up
0
Vote down
Cancel
ckuecker ckuecker
over 13 years ago
Chuck
Cancel
Vote up
0
Vote down
Cancel
