Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Failed to Access ETM Registers on PB1176?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Yan-Pai Chen
over 13 years ago
Note: This was originally posted on 30th December 2009 at
http://forums.arm.com
I'm trying to read/write ETM registers on PB1176 via a memory-mapped manner, but failed to access the memory range of ETM registers (the memory window of RVD shows all "!!!!!!!!" when I dump 0x10132000 ~ 0x10132FFF).
I don't use a RVT and connect with ETM/ETB according to the instruction in the article "How do I configure RVD v4.0/RVI v3.3 to capture ETM trace using the Embedded Trace Buffer (ETB) on the PB1176?" (
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.faqs/ka11701.html
The version of the tool suite is exactly RVD v4.0/RVI v3.3.
Does anyone can give me a hint or share the experience?
Thanks.
Peter Harris
over 13 years ago
I'm not sure if this is your problem, but worth a try...
The baseboard must be configured to run debug in CoreSight mode if you want to use the ETM - you will need to place a jumper header on the coresight jumper on the baseboard.
Cheers,
Iso
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cheers,
Iso
Cancel
Vote up
0
Vote down
Cancel
