Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
cortex-a8 : dual issue
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
rajeeva1807 rajeeva1807
over 13 years ago
Note: This was originally posted on 3rd November 2009 at
http://forums.arm.com
Hi every1!
1>
I'm running a piece of code on target Cortex-a8 on ARM Profiler 2.0 using RTSM. The profile analysis that I get doesn't show any instance of dual issue. I'm aware of the bottlenecks in case of dual issue i.e. only certain combinations can be dual issued. But in my case I'm not able to find even a single instance of dual issue happening. Could any1 suggest the cause behind it?
2>RVD: When I select Cortex-a8.dll while selecting the target on rv debugger, multiple emulation baseboard gets displayed in the right pane. I'm confused out of those, which baseboard will be suitable for embedded applications. Could anybody clarify on this?
Rajeeva
over 13 years ago
Note: This was originally posted on 5th November 2009 at
thanks for your replies.... i need further assistance
I am trying to run a particular project on
1.arm profiler 2.0(using rtsm) and
2. rtsm using rvd 4.0 (using performance counters)
Both experiments on Cortex-a8. But the counts that i get is quite surprising. Count in 2 and count in case 1 were in ratio of 2:3. I expect them to be more or less same as both are being rum on rtsm model.
Could any1 clarify on this?
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
As ttfn says the RTSM models are functional model and do not model pipeline features.
These models run fast because they sacrifice the pipeline model (cycle-accurate and cycle-approximate models which do provide this visibility are 10-1000 times slower than RTSM).
RTSM models essentially cross-compile the ARM binary into functionally equivalent x86 code and runs this native code on the host machine - as you are executing x86 code on an x86 processor you obviously see x86 pipeline performance when benchmarking =)
Performance counter events in RTSM, and cycles measured by the profiler are therefore only approximations - however command flow seen by the profiler will be correct.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
On 1, I asked ARM's support team once. The reply was that the model is functional, and it doesn't model low level details like dual issuing.
Cancel
Vote up
0
Vote down
Cancel
