Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Prefetch Abort while calling __main
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Gopi Gopi
over 13 years ago
Note: This was originally posted on 22nd October 2009 at
http://forums.arm.com
Hi All,
I am calling "__main" instead of "main" in my code for ZI data initialization, for copying code to ram, and for arm library initialization. But, during my program execution I'm facing Prefetch abort. This happens in "__rt_lib_init" function. Can anybody explain the reason for this ?
I solved it by adding the following code:
EXPORT __rt_lib_init
IMPORT main
__rt_lib_init
LDR R0, =main
BX R0
But why should I get Prefetch abort if I call "__rt_lib_init" ?
Note:
The arm core being used here is ARM7TDMI-S (no cache).
Compiler Options: --apcs /interwork --thumb -O2
Linker Options: --datacompressor off --callgraph
Thanks in advance,
Gopu.S
Martin Weidmann
over 13 years ago
I wouldn't suggest your work around as a long term solution.
If you are scattering loading, I would suspect that something in your scatter file is wrong. Scatter loading occurs in __main() before the call to _rt_lib_init(). I suggest that you double check your scatter file and compare with your memory map. You might also want to check if you stop before _rt_entry(), that memory contains what you expect it to.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
