Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
OpenMax DL library link error
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Rachit Shah
over 13 years ago
Note: This was originally posted on 7th October 2009 at
http://forums.arm.com
I have downloaded Optimize OpenMax DL library for Cortex-A8 from Arm Website and OpenMAX DL 1.0.2 Specification document from [url="
http://www.khronos.org/openmax/
http://www.khronos.org/openmax/[/url]
I was trying to check given example in OpneMax document using RVDS4.0 Evaluation Version on Windows PC.I was building application as linux executable using code sourcery lite tool chain.
I have built OpenMAX library using perl and which generated OMXsp.a under lib folder.
I have set User Include Path "C:\Documents and Settings\admin\Desktop \OX002-BU-0010-r2p0-00rel0\OX002-BU-00010-r2p0-00rel0\api" and "C:
\Documents and Settings\admin\Desktop\OX002-BU-0010-r2p0-00rel0
\OX002-BU-00010-r2p0-00rel0\sp\api" in Project Properties -> C/C++ Build -> Settings -> Tool Settings -> ARM RealView Compiler 4.0 -> Directory in that User Include Path (-I) option.
Properties -> C/C++ Build -> Settings -> Tool Settings -> ARM RealView Compiler 4.0 -> All options:
--cpu=Cortex-A8 -I"C:\Documents and Settings\admin\Desktop \OX002-BU-0010-r2p0-00rel0\OX002-BU-00010-r2p0-00rel0\api" -I"C:
--arm_linux_config_file=../arm_linux_config.xml
Similarly I have also include library search path and Library into Project Properties -> C/C++ Build -> Settings -> Tool Settings -> ARM RealView Linker 4.0 -> Directory :
Library Search Path(-userlibpath=) add "C:\Documents and Settings\admin\Desktop\OX002-BU-0010-r2p0-00rel0\OX002-BU-00010-r2p0-00rel0\lib"
Libraries add : OMXsp.a
When I have built My Example Project I got following error:
armlink : error L6242: Cannot link object amrCOMM_MastTable.o as its attributes are incompatible with the image attributes.
Also I have attached console output which details error.
This omxSP_FFTGetBufSize_C_SC16 function is declared in sp/api/omxSP.h
If i build same application as bare-metal then it is building without any linking error.
Thanks,
Rachit shah
www.rzr.online.fr rzr
over 13 years ago
Note: This was originally posted on 23rd August 2011 at
may this help on link issues :
http://forums.arm.com/index.php?/topic/15179-help-binutils-ld-crash-when-linking-armcc-objects-and-gcc-ones/page__pid__36592#entry36592
Cancel
Vote up
0
Vote down
Cancel
Guang Yang
over 13 years ago
Note: This was originally posted on 15th November 2011 at
I don't know if this thread is still active or not. But I am also trying to use OpenMax DL library provided by the ARM's website
https://silver.arm.com/browse/OX002
. I was stuck at a more preliminary stage: generating the archive file. I don't have the license for RVDS4, so I used DS-5's command prompt instead. When I am trying to build the library following the instruction of release note" perl build_vc.pl". Instead of the building successfully, I got the message "can't obtain the license of the assembler with version >5.02". The license I have is from the license server of my university. I wonder if there is a way to go around building the archive in DS 5 environment?
Thanks,
Cancel
Vote up
0
Vote down
Cancel
