Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Cortex M1, Cortex R4 - comparison
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Mullai Thiagu
over 13 years ago
Note: This was originally posted on 25th September 2009 at
http://forums.arm.com
Hi all,
Iam studyng the features supported by Cortex M1 and Cortex R4 soft processors. I have created a table for this and there are some features which i could not find.... it would be helpful if you guys can fill the missing features
guestposter guestposter
over 13 years ago
Features
1. Primary FPGA Target
Cortex-M1 deliverables supports Altera, Actel, Xilinx FPGA (for licensed customers).
Current available FPGA kits include Altera version and Actel version.
Cortex-R4 does not have FPGA kit as a product, but ARM customers can get FPGA prototype platform for Cortex-R4.
2. Max Core Frequency
Cortex-M1 : It depends : What FPGA?
You can get even higher speed if you are using newer Stratrix / Virtex devices.
Cortex-R4 : It is not optimized for FPGA. For ASIC version you can get it to 600MHz with hardened version (Cortex-R4X)
3. FPGA Logic Cells
Cortex-M1:This depends on RTL options, it shown as 2600 Logic elements in Altera website
4. Hardware Multipliers
Cortex-M1 : Yes
Cortex-R4 : Yes
5. Hardware Dividers
Cortex-M1 : No
Cortex-R4 : Yes
6. Instruction Cache Size
Cortex-M1 : No cache, TCM only (up to 1MB).
Cortex-R4 : Depends on configuration, TCM also depends on configuration
7. Data Cache Size
8. Number of ports for Instruction TCM / TCM-A (for Cortex R4)
64-bit TCM interface
9. Number of ports for Data TCM / TCM-B (for Cortex R4)
2 x 64-bit TCM interface
10. Burst Size Setting for Cache
Cortex-R4 : Programmable by CP15
11. Exception Checking (Divsion error)
Cortex-R4 : Yes
12. MPU present/absent
Cortex-M1 : No
Cortex-R4 : Yes
13. MMU present/absent
Cortex-M1 : No
Cortex-R4 : No
14. Maximum number of Interrupts supported
Cortex-M1 : 32
Cortex-R4 : Depends on interrupt controller
15. Options to select JTAG debug level - present/absent
Cortex-M1 : Depends on which FPGA development you are using (e.g. with SOPC builder debug is carried out via the USB blaster connection)
Cortex-R4 : Depends on which debug port component you connected it to.
16. Option to set Custom instructions - present/absent
Cortex-M1 : No
Cortex-R4 : No
17. Option to Set memory for Exception Vector - present/absent
Cortex-M1 :Vector table at address 0x0 (can be AHB or TCM)
Cortex-R4 : Vector table at address 0x0 or VIC interface
18. Is a separate FPGA kit (evaluation version) available for Cyclone III FPGA
Cortex-M1 only : FPGA kit available (not sure about evaluation)
19. If Yes, does the kit consist of:
Cortex-M1 only
Soft Core : Yes
Software development environment : Yes
Simulation support (for full version) : You need to get ask distributor about this
20. Tool for Software development
Cortex-M1 kit include ARM RealView Microcontroller Development Kit
21. AMBA Bus Support - present/absent
Cortex-M1 for Actel use AMBA
Cortex-M1 for Altera use Avalon
Cortex-R4 use AMBA (AXI)
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Features
3. FPGA Logic Cells
Cortex-M1 : Yes
Cortex-R4 : Yes
Cortex-M1 : No
Cortex-R4 : Yes
7. Data Cache Size
Cortex-R4 : Yes
Cortex-M1 : No
Cortex-R4 : Yes
Cortex-M1 : No
Cortex-R4 : No
Cortex-M1 : 32
Cortex-M1 : No
Cortex-R4 : No
Cortex-M1 only
Soft Core : Yes
Cancel
Vote up
0
Vote down
Cancel
