Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
function argument assigne to ARM register in assembly
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Rachit Shah
over 13 years ago
Note: This was originally posted on 4th September 2009 at
http://forums.arm.com
I am developing application on OMAP3530-beagleboard using code sourcery tool chain.
I have used assembly function in my C application.Function has 5 argument it's called from another c function.
function like: void routine(signed char *a, int b, signed char *c, unsigned char *d, unsigned int *e)
asm volatile{
........assembly syntaxs....
Here, function argument a to d are stored in r0 to r3 but argument e either go to stack or store into r4 to r12 register as per called function ?
How can i write assembly syntax in my assembly function to get value of argument e in any specific register so I can use in my function correctly?
How can I write assembly syntax so assembly function parameter passing become independent of called function variable usage means I can use this routine function any other application without doing changed inside the assembly syntax to catch parameter value ?
Thanks,
Bhaveet Shah
over 13 years ago
Note: This was originally posted on 8th September 2009 at
Have you checked the disassembly of the code when you call the function to check the compiler has done the right thing? Have you checked the code generated by the compiler for your assembly function? The code you've shown looks correct for getting the 'e' pointer into r4, but you haven't explained enough for us to help. What do you do with r4? Where are you using it? etc
Cancel
Vote up
0
Vote down
Cancel
Bhaveet Shah
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
