Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Neon reg to ARM reg data transfer
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Vishwa Vishwa
over 13 years ago
Note: This was originally posted on 30th July 2009 at
http://forums.arm.com
I m transferring data from neon register to arm register, which is very costly.
i.e., it takes each vmov.32 r6,do[2] takes around 13 to 18 cycles.
This is proving to be very costly for a function which runs for many times.
Can anyone please suggest a way out of this???
Thanks in advance for any help..... :)
Vishwa Vishwa
over 13 years ago
Note: This was originally posted on 31st July 2009 at
Thanks !!
So one option wud b if possible convert all arm involved operations to Neon operations.........
Cancel
Vote up
0
Vote down
Cancel
Vishwa Vishwa
over 13 years ago
Note: This was originally posted on 3rd August 2009 at
Thanks !!!!
Cancel
Vote up
0
Vote down
Cancel
Vishwa Vishwa
over 13 years ago
Note: This was originally posted on 13th August 2009 at
Hi guys,
I found a way out of this. There were some 16 such instructions(neon to arm transfer instructions) in my function. So accounting for some 208 cycles per call, (latency for vmov.u32 r6,d26[0] = 14).And this function was getting called some 20 thousand times. It was eating up lot of time.
But i had a opportunity in it. Interleaving 14 independent instructions in between.
code was something like this:
vmov.32 r6,d[0]
- instrns which use r6-
- instrn-
- instrn-
- instrn- ........
vmov.32 r6,d[0]
- instrn-
- instrn-
- instrn- ..........
................etc
So looking at the code structure, an option left is interleave. Take out the instructions which use the immediate result of r6 and insert them just before next neon to arm transfer instrn. This is assuming that the instrns in between are independent. This gave a gain of around 4%.
Thanks a lot for your help!!!!!!!
Cancel
Vote up
0
Vote down
Cancel
unclep unclep
over 13 years ago
You might find example Cortex-A8-optimized code useful, such as this:
[url="
http://www.arm.com/products/multimedia/openmax/
http://www.arm.com/products/multimedia/openmax/[/url]
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
You cannot reduce the NEON-ARM or ARM-NEON register move costs - these are caused by the microarchitecture of the NEON unit for the Cortex-A8.
One of the key parts of vectorizing for the Neon unit is to try and minimize the interaction between the main ARM pipeline and the NEON unit - pushing relatively large blocks of code through the NEON without too much dependence on what is happening on the ARM-pipeline. Any interaction is fairly time consuming as you have noted, but for many common tasks such a media CODECs the need for interaction is actually quite low.
It is worth noting that the NEON unit has its own load store hardware so the NEON code can make its own memory accesses, and does *not* need the ARM to load data for it (this then has to be vmov'd in to the NEON which is slow).
Cancel
Vote up
0
Vote down
Cancel
