Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM cache in simulator
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
ManishKesarkar ManishKesarkar
over 13 years ago
Note: This was originally posted on 27th July 2009 at
http://forums.arm.com
Hi
I am using RVDS 4.0 Real view Instruction set simulator for ARM926EJS target. While configuring the target using ARMulator dialog box I get option MMU/MPU initialization when I select this option I get 60 % reduction in total cycles for my code. When this option is not selected the code for cache enabling is included it has no effect and I 60% increase in cycles is observed. So does this option enables cache does and uses default MMU/MPU tables for cache?
The core configuration I am using is as follows
ARM926EJ-S, 16Kb I-cache, 16Kb D-cache, 64Kb I-Ram, 64KB D-Ram,
Memory Management Unit, I-uTLB, D-uTLB, TLB, BIU, Little endian,
Debug Comms Channel, 4GB, Pagetables, Mapfile, Timer, Profiler,
SIMRDI MemCallback, Tube, Millisecond [6666.67 cycles_per_millisecond], IntCtrl,
Also in above waht does figure [6666.67 cycles_per_millisecond] indicates?
Martin Weidmann
over 13 years ago
In the second scenario are you just enabling the caches, or also configurring the MMU? On the 926 all data accesses are treated as non-cacheable while the MMU is disabled.
Are you using RVDS? If so, you should have a 926 MMU/cache initialization example included.
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
