Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
VZIP instruction
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
VZIP instruction
Rachit Shah
over 13 years ago
Note: This was originally posted on 25th June 2009 at
http://forums.arm.com
I am using NEON instructions in my application as Inline Assembly routine.
I am getting some different out put by executing VZIP instruction.
As per ARM DDI0406B_arm_architecture_reference_manual.pdf (Page A8-806), It should interleaves data as per size.
I have used "VZIP.8 D8,D12" instruction. D8 and D12 values are as per below
D8 = { 0x94,0x4f,0x51,0x55,0x51,0x55,0x55,0x4f}
D12 = {0x6a,0x4f,0x51,0x55,0x51,0x55,0x55,0x4f}
As per manual, after executing instruction output should be as per below
D8 = {0x94,0x6a,0x4f,0x4f,0x51,0x51,0x55,0x55}
D12 ={0x51,0x51,0x55,0x55,0x55,0x55,0x4f,0x4f}
Instead of above output, I am getting different as per below.
D8 = {0x94, 0x94, 0x94, 0x94, 0x51, 0x51, 0x55, 0x55}
D12 = {0x51, 0x51, 0x51, 0x51, 0x55, 0x55, 0x4f, 0x4f}
I am using QEMU Simulator option for debugging application.
Please guide me, what are other settings require at time of instruction execution to get output proper?
Rachit Shah
over 13 years ago
Note: This was originally posted on 26th June 2009 at
Hello sim,
I am sure about input and output values.
I was also thinking same. I was checking though QEMU and other instructions giving right values so I though it could be some syntax problem.
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
Regardless of the exact permutation VZIP performs, it doesn't replicate any bytes, thus obtaining more than one byte 0x94 suggests that something is wrong. If you are sure of the input and output values, then this would appear to be a bug in QEMU.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
