Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Unaligned access problems
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Felix Varghese
over 13 years ago
Note: This was originally posted on 1st June 2009 at
http://forums.arm.com
We had written some code for an ARM Cortex M3 platform. But now, we have to port it to an ARM7TDMI based controller in very little time. The problem is the former supports unaligned access, but the latter doesnt. Now, we have lots of code of the form:
unsigned int a;
char b[100];
a = *( ( unsigned int *) &b[5] );
As you can see, we were using typecasts to copy 4-byte entities and also 2 byte entities in many places. We are using IAR compiler. The code works fine when run on Cortex M3 but when ARM7TDMI encounters this kind of instructions, it goes into abort. Is there any way we can cause the compiler to generate appropriate instructions so that aborts do not occur, other than replacing all of this kind of instructions with byte-wise memcopys ?
Peter Harris
over 13 years ago
A C compiler will always generally assume that integers are aligned - so there is normally no "quick" solution to this problem. Casting an integer to an unaligned memory address is not strictly valid C, so you are really in to implementation defined behavior of the compiler.
With the RealView tools you can make a pointer point to a packed object - which will generate either unaligned accesses or byte accesses depending on the CPU you have chosen and the presence of the --[no-]unaligned flag:
__packed int *pMyInt;
There might be an equivalent for the IAR tools - but it varies from tool to tool ...
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
