Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Is there something like sizeof(function) ?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
zart zurt
over 13 years ago
Note: This was originally posted on 7th May 2009 at
http://forums.arm.com
I want to do IAP (In-Application Programming). In order to do this, I will copy several C functions from IROM to IRAM and then execute them there. If there was a sizeof operator for functions than it would be trivial but AFAIK there is none.
To accomplish this, I have created dummy start_of_module & end_of_module marker functions to get addresses of them. That way, I can calculate the size of the module and copy all of functions and find their relative addresses, but I noticed that the compiled functions may be ordered different than they appear in source code. I see this by reading the assembly listing of the module.
Some functions are static but that is all there is...
Any info/suggestion , linker hack , whatever ?
Thanks In Advance...
EOT
zart zurt
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Samar Samar
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
Note: This was originally posted on 8th May 2009 at
> *SNIP*
You must NOT enable "Optimize for Time"
You must check ASM output for Optimized builds
The function must have 1 and only 1 exit point
The function can not have static & const variables
The function can not access non-local/non-param variables
The function can not have hidden const variable (note[0])
> *SNIP*
That's a pretty long list of things which won't work. If optimization for time causes things to break you may find other optimizations possible with O3 OSpace also cause problems.
Samar has the right idea. Linkers (generally) manage code and data references by manipulating sections and then fixing up inter-section references if the section moves (called relocations). Moving sections around (and performing appropriate relocations if they are needed) means that code stays functional relative to other addresses in the same section.
Cancel
Vote up
0
Vote down
Cancel
