Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Address Translation and Attributes
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Samar Samar
over 13 years ago
Note: This was originally posted on 24th April 2009 at
http://forums.arm.com
I have a memory section mapping as below:
______address_________|_physical_____________|_d_|_size____|_permissions________
____________|_glb|_shr|_access
__C:B0200000--B02FFFFF|__A:01E00000--01EFFFFF|_0F|_00100000|_P:readwrite_U:readwrite________|_yes|_no_|_write-through/buffered
The first level descriptor is at address 00A26C04
___address__|________0________4________8________
SD:00A26C00| >01E00DEA
Hence the physical address for B0200000 is 01E00000.
The Attributes are 0x00DEA.
C = 1
B = 0
XN = 0
domain (d) = 0xF
AP = 0x11
TEX = 0x000
Type = Section (1MB)
TEX (0x000) and CB (0x10) indicate cache policy of Outer and inner write through, no write allocate so my questions are:
1. What determines if it is buffered/non-buffered?
2. Is buffered/non-buffered referring to the use of write buffers?
3. What do inner and outer mean on the system that only have L1 cache?
4. If a memory region is shared between processors and its attributes are non-cache/buffered then do I have to perform data memory barrier operation after writing to any location in that region?
Thanks,
Samar
Peter Harris
over 13 years ago
[url="
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0333g/ch06s07s06.html
http://infocenter.arm.com/help/index.jsp?t...ch06s07s06.html[/url]
Yes.
L1 is always inner. You have no outer in your case. Note that caches more distant from the core are sometimes configured as "inner", but normally are "outer".
It will "eventually" hit the external memory system. If you want to ensure it has been committed to the external memory before signaling the other processing device, then yes you will need a cache clean or clean+invalidate followed by a DMB.
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 13 years ago
[url="
Yes.
Cancel
Vote up
0
Vote down
Cancel
