Pre-purchase inquiry: Power supply evaluation for DSTREAM-ST (DSTRMST-KT-0197A) due to Japanese PSE regulations
I am considering purchasing the DSTREAM-ST (DSTRMST-KT-0197A) for a new development project in my lab in Japan.
Before finalizing the purchase, I need to ensure that the setup complies with the local PSE (Electrical Appliance and Material Safety Law) in Japan. Since the original AC adapter included in the kit might not be PSE-certified, I am planning to source a domestic PSE-compliant power supply.
To select the correct alternative, could you please provide the official electrical specifications for both the DSTREAM-ST main unit's power input and the original AC adapter?
1. Main Unit (DSTREAM-ST) Power Requirements:
Required Input Voltage and tolerance.
Peak/Typical Input Current.
2. Original AC Adapter Specifications (for our evaluation):
DC Output: Voltage and Current.
DC Plug: Barrel dimensions (Inner/Outer diameter) and Polarity (Center Positive?).
AC Input: Voltage range, Frequency range (e.g., 100V-240V, 50/60Hz), and the specific AC plug type/shape.
We are currently evaluating a 5V/5A, Center Positive, 5.5mm/2.1mm domestic adapter. I would appreciate it if you could confirm if these specs are fully compatible with the current hardware revision of the DSTREAM-ST.
Thank you in advance for your technical support.
Best regards,
