Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
The same instruction,realview compile correct, but arm-gcc compile get error!
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Eric mao
over 13 years ago
Note: This was originally posted on 24th July 2012 at
http://forums.arm.com
Hi all
The instruction VSUBL Q3.S16, D0.U8, D2.U8 compiler correctly use realview, but when use arm-gcc ,get error: "neonAsm.s:13: Error: inconsistent types in Neon instruction -- `vsubl Q3.S16,D0.U8,D2.U8' "
Peter Harris
over 13 years ago
The size specifier is attached to the instruction, not the register.
vsubl.u8 q3, d0, d2
Cancel
Vote up
0
Vote down
Cancel
Eric mao
over 13 years ago
Note: This was originally posted on 25th July 2012 at
Hi isogen74
Thank you for reply. The problem is solved when use the instruction as you say! I used to use the datasize just after the instruction, but i see the openmax's assembly file use the datasize after register.
Cancel
Vote up
0
Vote down
Cancel
