Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
How to shuffle bits and Check high bit value using Neon Intrinsics?
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Rahul Budhiraja
over 13 years ago
Note: This was originally posted on 1st November 2011 at
http://forums.arm.com
I am trying to convert a code written in SSE3 intrinsics to NEON SIMD and am stuck because of a shuffle function.I have looked at the
GCC Intrinsic
s ,
ARM manuals
but have not been able to find a solution
Is there any equivalent function for the
_mm_shuffle_epi8
function in SSE3 .Any suggestions on how to implement this would be really appreciated since I cant seem to get past this.I know that a lookup-table exists ,but it does not do an initial comparison like the _mm_shuffle ,so i am not sure how to implement this.
Also,I need to check only the high bit values of each byte in a register.Is there any way to check the high-bit value of each element in a vector ?I looked at the manual and was not able to find anything relevant.Any help/info would be sincerely appreciated.
Cheers,
Gilead Kutnick
over 13 years ago
Note: This was originally posted on 2nd November 2011 at
vtbl actually does have a special case for setting the value to zero. The only difference between it and SSSE3's pshufb is that it will set the result to zero if any of the out of range bits of the index are set, not just if the most significant bit is. If you're using tables of 16 values like pshufb that refers to bits 4 through 7 of the indexes. If for some reason your input has any of bits 4 through 6 you can clear them before the vtbl by using vand or vbic.
You do have to use vtbl twice to get both the lower and upper part, if you're working with 128-bit vectors.
As for your second question, we need to know more about what you mean by "look" at the most significant bits. If you want to generate a byte-mask that's 0xFF where the MSB is set and 0x00 where it isn't you can accomplish it with vclt.s8 #0, vtst.8, or vshr.s8 (I recommend the first one). If you want to pack the MSBs into an 8-bit mask like pmovmskb does that'll take more code. If at all possible it'd be best to change the algorithm to not need this. But if you must have it you can do it with the following:
- Expand the MSB to to a byte mask using one of the above methods
- Isolate a different single bit in each byte by ANDing the byte mask against a vector containing { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 }
- Combine the bits using a series of three parallel adds (vpadd)
This works best if you can do it over more than one vector worth of bytes so the later vpadds have more data to work with, and can hide latency better.
Cancel
Vote up
0
Vote down
Cancel
Gilead Kutnick
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
