Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Problems compiling assembly for cortex m3
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Gestur Palsson
over 13 years ago
Note: This was originally posted on 20th February 2011 at
http://forums.arm.com
My platform is Stellaris Cortex M3 and I'm using one of the recent releases of Codesourcery Lite toolchain.
I'm trying to put an assembly source file to my project and edit my makefile to compile it along with all the *.c files.
My issue is that I'm getting the following error message, compiling the assembly file:
asmFile.s:235: Error: ARM register expected -- `ldrsh xi,[a,#2]'
Currently I'm configuring my compiler flags like this:
ASMFLAGS = -mthumb -mcpu=cortex-m3 -x assembler-with-cpp -adhlmns
The assembly file is using #define's for re-defining register names, as well as macros for some pre-defined actions.
I think I need some basic suggestions on how to configure my arm-none-eabi-gcc compiler, to compile and pre-process an assembly file.
Any hints on how to tweak the compiler to correctly compile my assembly?
Regards
palsson
Simon Craske
over 13 years ago
Note: This was originally posted on 21st February 2011 at
If you're using gcc rather than as; then a simple solution is just to rename the file from "asmFile.s" to "asmFile.S"
(note the capital .S), e.g.:
# arm-none-linux-gnueabi-gcc -c -mcpu=cortex-m3 -mthumb asmFile.S
hth
s.
Cancel
Vote up
0
Vote down
Cancel
Gestur Palsson
over 13 years ago
Note: This was originally posted on 22nd February 2011 at
Hi S,
Unfortunately, it is not that easy :-)
If I remove all macros and register re-definitions, #define's, it can compile.
So, I need hints on compiler flags to enable macros and register definitions (pre-processing)
Thanks...
Regards
palsson
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
Palsson,
Did you actually try my suggestion? GCC when given a file ending in a lower case ".s" just sends the file to GAS; if however it ends in a capital ".S", it sends it to CPP before sending it to GAS.
hth
s.
Cancel
Vote up
0
Vote down
Cancel
Gestur Palsson
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
