aga-daemon: Aborted (core dumped) at runtime
Hi All,
I using aga-daemon in Linux base. but i will see Aborted (core dumped) at last time.
Env:
  • DS 2021.1  Graphic Analyzer 5.8.0
  • Linux 4.9.119 #1 SMP PREEMPT Fri Dec 30 09:56:16 UTC 2022 armv7l GNU/Linux
  • Libs
    Libs
    板子
    librt.so.1
    librt-2.31.so
    libatomic.so.1
    libatomic.so.1.2.0
    libdl.so.2
    libdl-2.31.so
    libm.so.6
    libm-2.31.so
    libgcc_s.so.1
    libgcc_s.so.1
    libpthread.so.0
    libpthread-2.31.so
    libc.so.6
    libc-2.31.so
    ld-linux-armhf.so.3
    ld-2.31.so
Error Msg:
  • Only ./aga-daemon
    terminate called after throwing an instance of 'std::bad_cast'
      what():  std::bad_cast
  • libEGL & libGLES* link to libinterceptor + aga-daemon
    terminate called without an active exception
Thank you
Haru Zheng
  • Hi Haru,
    I am Ghufran and I work here at Arm. Thank you for reporting the error. Can you please confirm which target binaries you are running? It will also be useful if you can provide the commands.
    Is it possible for you to try a newer version of Graphics Analyzer? the latest version is 5.12.
    Thanks,
    Ghufran
  • Hi Ghufran
    C:\Program Files\Arm\Development Studio 2021.1\sw\graphics_analyzer\target\linux\arm\32-bit_hardfloat
    # LD_LIBRARY_PATH=/lib:/usr/lib LD_PRELOAD=./libinterceptor.so ./aga-daemon
    1672305110263: aga_daemon[2471]: [2471]:INFO: Main: The Graphics Analyzer daemon is starting
    Daemon is version: D027
    Socket is: \0aga-daemon
    1672305110281: aga_daemon[2471]: [2471]:ERROR: DlOpenInterceptor: Unable to open library: ./aga-daemon
    1672305110282: aga_daemon[2471]: [2471]:ERROR: DlOpenInterceptor: Unable to open library: ./aga-daemon
    1672305110292: aga_daemon[2471]: [2471]:ERROR: DeviceInfo: Unable to load GPU information (GL_VENDOR, GL_RENDERER, GL_VERSION) for this device.
    1672305110292: aga_daemon[2471]: [2471]:ERROR: DeviceInfo: eglInitialize, EGL error: 0x3001
    1672305110293: aga_daemon[2471]: [2471]:INFO: HostConnection: Initializing host connection
    1672305110293: aga_daemon[2471]: [2471]:TRACE: SocketLinux: Waiting for connections on Unix (PF_UNIX) socket bound as server to abstract Unix socket "\0aga-daemon" with socket no. 1 / FD 7
    1672305110293: aga_daemon[2471]: [2471]:INFO: InterceptorListener: Initializing interceptor listener
    1672305110293: aga_daemon[2471]: [2471]:INFO: Daemon: Daemon initializing
    1672305110293: aga_daemon[2471]: [2494]:INFO: HostConnection: Host connection listening
    1672305110293: aga_daemon[2471]: [2495]:INFO: InterceptorListener: Interceptor Listener waiting for connections
    1672305110293: aga_daemon[2471]: [2494]:TRACE: SocketLinux: Waiting for connections on Internet ver.6 (PF_INET6) socket bound as server to :: with socket no. 0 / FD 9
    1672305110294: aga_daemon[2471]: [2496]:INFO: Daemon: Daemon running
    1672305110294: aga_daemon[2471]: [2496]:INFO: Daemon: Daemon is version: D027
     > It will also be useful if you can provide the commands.
    1. ./aga-daemon
    2. LD_LIBRARY_PATH=/lib:/usr/lib LD_PRELOAD=./libinterceptor.so ./aga-daemon
    3. libEGL & libGLES* link to libinterceptor + aga-daemon
      ln -s libinterceptor.so libEGL.so;
      ln -s libinterceptor.so libEGL.so.1
      ln -s libinterceptor.so libGLESv1_CM.so
      ln -s libinterceptor.so libGLESv1_CM.so.1
      ln -s libinterceptor.so libGLESv2.so
      ln -s libinterceptor.so libGLESv2.so.2
    1. ./aga-daemon
      # ./aga-daemon
      1673318461953: aga_daemon[969]: [969]:INFO: Main: The Graphics Analyzer daemon is starting
      Daemon is version: D032
      1673318482379: aga_daemon[1139]: [1139]:INFO: Main: The Graphics Analyzer daemon is starting
      1673318482395: aga_daemon[1139]: [1139]:ERROR: DlOpenInterceptor: Unable to open library: ./aga-daemon
      1673318482396: aga_daemon[1139]: [1139]:ERROR: DlOpenInterceptor: Unable to open library: ./aga-daemon
      1673318482411: aga_daemon[1139]: [1139]:DEBUG: DeviceInfo: GL_VENDOR = ARM, GL_RENDERER = Mali-G31, GL_VERSION = OpenGL ES 3.2 v1.r29p0-01eac0.c395bfb72e7d98618c6deddd220ea9e5, OS_ARCHITECTURE = 32-bit
      1673318482412: aga_daemon[1139]: [1139]:INFO: HostConnection: Initializing host connection
      1673318482413: aga_daemon[1139]: [1139]:ERROR: Main: Failed to bind server socket: errno = 98 (Address already in use)
      1673318482413: aga_daemon[1139]: [1139]:ERROR: Main: Error initialising daemon - is Graphics Analyzer daemon already running?
      # ln -s libinterceptor.so libEGL.so;
      # ln -s libinterceptor.so libEGL.so.1
      # ln -s libinterceptor.so libGLESv1_CM.so
      # ln -s libinterceptor.so libGLESv1_CM.so.1
      # ln -s libinterceptor.so libGLESv2.so
      # ln -s libinterceptor.so libGLESv2.so.2
      1673318683135: aga_daemon[4129]: [4129]:INFO: Main: The Graphics Analyzer daemon is starting
      1673318683138: aga_interceptor[4129]: [4129]:ERROR: PassThroughClApi: Could not find any libraries for 'cl'. Looked in the following places: {/usr/lib/libOpenCL.so, /usr/lib64/libOpenCL.so, /usr/lib32/libOpenCL.so, libOpenCL.so}
      1673318683155: aga_interceptor[4129]: [4129]:INFO: PassThroughEglApi: Found the following libraries for 'egl': {/usr/lib/libEGL.so, libEGL.so}
      1673318683157: aga_interceptor[4129]: [4129]:INFO: PassThroughGlesApi: Found the following libraries for 'gles': {/usr/lib/libGLESv2.so, /usr/lib/libGLESv1_CM.so, libGLESv2.so, libGLESv1_CM.so}
      1673318683169: aga_interceptor[4129]: [4129]:TRACE: SocketLinux: Unix (PF_UNIX) socket connected to abstract Unix socket "\0aga-daemon" with socket no. 0 / FD 3
      1673318683169: aga_daemon[26894]: [26903]:TRACE: SocketLinux: Accepted connection from process with PID 4129 on Unix (PF_UNIX) socket (new socket no. 4 / FD 12; parent socket no. 1 / FD 9)
      1673318683169: aga_daemon[26894]: [26903]:INFO: InterceptorConnection: Initializing interceptor connection
      1673318683169: aga_daemon[26894]: [26903]:INFO: Daemon: onInterceptorConnected
      1673318683169: aga_daemon[26894]: [26903]:INFO: Protocol: Sending host detached command to Interceptor for process 4129
      1673318683169: aga_interceptor[4129]: [4129]:WARNING: GatorConnection: Not connected to gatord, the application will run normally but Streamline will not collect annotations. To collect annotations, please verify you are running gatord 5.22 or later and that SELinux is disabled.
      1673318683169: aga_daemon[26894]: [4131]:INFO: InterceptorConnection: Interceptor connection waiting
      1673318683172: aga_interceptor[4129]: [4129]:ERROR: Interceptor: MGD failed to read the process whitelist file: basic_ios::clear: iostream error
      1673318683172: aga_interceptor[4129]: [4129]:INFO: MarshallerBase: Connecting to daemon. Sending header...
      1673318683173: aga_interceptor[4129]: [4129]:INFO: Interceptor: Interceptor loaded for 4129: ./aga-daemon
      1673318683173: aga_daemon[26894]: [4131]:WARNING: InterceptorConnection: InterceptorConnection::run threw an exception: Interceptor connection with version D032 refused. Only version D027 is accepted. Please make sure that the Graphics Analyzer daemon and Graphics Analyzer interceptor are from the same Graphics Analyzer release.
      1673318683173: aga_daemon[26894]: [4131]:WARNING: InterceptorConnection: If a traced application was just terminated, this message is expected and can be ignored.
      1673318683173: aga_interceptor[4129]: [4129]:INFO: Interceptor: Activating tracing
      1673318683173: aga_daemon[26894]: [4131]:INFO: Daemon: onInterceptorDisconnected
      1673318683173: aga_daemon[26894]: [4131]:INFO: Daemon: Sending process ended message to host for pid: 4129
      1673318683173: aga_daemon[26894]: [4131]:TRACE: SocketLinux: Closing Unix (PF_UNIX) socket with socket no. 4 / FD 12
      1673318683173: aga_daemon[26894]: [4131]:INFO: InterceptorConnection: Interceptor connection closed
      1673318683173: aga_interceptor[4129]: [4133]:DEBUG: SocketLinux: Remote closed connection (but may still be data to read) on Unix (PF_UNIX) socket connected to abstract Unix socket "\0aga-daemon" with socket no. 0 / FD 3
      1673318683173: aga_interceptor[4129]: [4133]:INFO: ListenerThread: Received new message: C:1 E:0 F:0
      1673318683174: aga_interceptor[4129]: [4133]:INFO: Interceptor: Host detached
      1673318685190: aga_interceptor[4129]: [4133]:DEBUG: SocketLinux: Remote closed connection (but may still be data to read) on Unix (PF_UNIX) socket connected to abstract Unix socket "\0aga-daemon" with socket no. 0 / FD 3
    Thanks.
    Haru
  • Hi Haru,
    This is Mark from Arm. I'm really sorry you are continuing to have problems.
    As a DS customer, you are entitled to raise support tickets. We need to continue this discussion in a support ticket, so please would you create a ticket about this issue in order for us to help you further?
    That said, I will briefly address potential causes of this issue in this forum. You have given us three ways in which you ran "aga-daemon". Only one of them seems to be correct.
    The normal correct approach was simply typing "./aga-daemon". In your new support ticket, could you confirm that you do not have symbolic links set up to "libinterceptor.so" (as you do for your third way of running "aga-daemon")? Again in the support ticket, could also you send us the environment in which you are running "aga-daemon" (type "env" at the command line)? In particular, can you confirm that you do not have special settings of LD_LIBRARY_PATH and/or LD_PRELOAD? If that doesn't help us, we will probably want to analyse the core file produced when "aga-daemon" crashes.
    You also gave two incorrect ways of running "aga-daemon":
    a. You ran the daemon by typing "LD_LIBRARY_PATH=/lib:/usr/lib LD_PRELOAD=./libinterceptor.so ./aga-daemon". This is incorrect: "libinterceptor.so" must *not* be pre-loaded when you run aga-daemon.
    b. You also set up some symbolic links, then set LD_LIBRARY_PATH to "/lib:/usr/lib" and LD_PRELOAD to point at "libinterceptor.so". This is incorrect: again, LD_PRELOAD must not point at "libinterceptor.so" when "aga-daemon" is running. I'm not sure whether this approach is based upon section 7.1 of the user documentation. To be clear, that section is not relevant to running "aga-daemon" and should not be used for that purpose. Instead, it is speaking about another way of running monitored applications. (Incidentally, your settings of LD_PRELOAD / LD_LIBRARY_PATH are not consistent with the instructions in that section.)
    Thanks and regards,
    Mark
  • Hi Mark
    I unable to report support tickets, because I not has way with ARM Support, i just has agent email, but it not reply to me. So I report to here.
    My env:
    # env
    SHELL=/bin/sh
    TERM=xterm
    HUSHLOGIN=FALSE
    OLDPWD=/home/root
    USER=root
    LD_LIBRARY_PATH=/usr/lib:/usr/lib/realtek
    SYSTEMD_PAGER=/bin/cat
    MAIL=/var/spool/mail/root
    PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin
    PWD=/nvram/armds/hf
    QT_QPA_EGLFS_HIDECURSOR=1
    EDITOR=vi
    QT_QPA_FONTDIR=/usr/share/fonts
    PS1=\u@\h:\w\$
    SHLVL=1
    HOME=/home/root
    LOGNAME=root
    RMF_USE_SOUPHTTPSRC=true
    _=/usr/bin/env
    Not, it(correct) is not show GPU info, and it is unable to open library.
    This like *2.4.3 Connect the host and the target*, but it will be got "terminate called after throwing an instance of 'std::bad_cast'".
    I try to section 7.1, but it is not work. like:
    a. LD_LIBRARY_PATH=/lib:/usr/lib:/nvram/armds/hf/libinterceptor.so MGD_LIBRARY_PATH=/usr/lib /nvram/armds/hf/aga-daemon
    # LD_LIBRARY_PATH=/lib:/usr/lib:/nvram/armds/hf/libinterceptor.so MGD_LIBRARY_PATH=/usr/lib /nvram/armds/hf/aga-daemon
    1673431874684: aga_daemon[17193]: [17193]:INFO: Main: The Graphics Analyzer daemon is starting
    terminate called after throwing [92424.862254] audit_printk_skb: 33 callbacks suppressed
    [92424.862261] audit: type=1701 audit(1673431874.701:178): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=17193 comm="aga-daemon" exe="/nvram/armds/hf/aga-daemon" sig=6
    b. libEGL & libGLES* link to libinterceptor + aga-daemon
    1673431931038: aga_daemon[17971]: [17971]:INFO: Main: The Graphics Analyzer daemon is starting
    1673431931057: aga_daemon[17971]: [17971]:ERROR: DlOpenInterceptor: Unable to open library: /nvram/armds/hf/aga-daemon
    1673431931057: aga_daemon[17971]: [17971]:ERROR: DlOpenInterceptor: Unable to op[92481.244446] audit: type=1701 audit(1673431931.079:179): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=17971 comm="aga-daemon" exe="/nvram/armds/hf/aga-daemon" sig=6
    1673431931058: aga_daemon[17971]: [17971]:ERROR: DlOpenInterceptor: Unable to open library: /nvram/armds/hf/aga-daemon
    Thanks. But I not has any-way to report ticket, like jira.
    Haru
  • You can open a support case from here:
    developer.arm.com/support
    Kind regards,
    Pete
