Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Using ARM's OpenMAX DL with GNU compiler
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Jamie Martini
over 13 years ago
Note: This was originally posted on 27th October 2010 at
http://forums.arm.com
I have a project in XCode with the target having an ARM11 processor. I would like a faster FFT, so wanted to check out ARM's OpenMAX DL implementation. When I try building with the source files included, I am getting bad instruction errors in all of the .s files. I have been doing some research and people have suggested that there is a different syntax between the ARM RVCT, used to create these .s files, and GNU compliers, which I am using in XCode. Could this be causing these errors? If so, are there any resources on the differnces between the two compilers?
Thanks!
Jamie
www.rzr.online.fr rzr
over 13 years ago
Note: This was originally posted on 21st July 2011 at
I am wondering if there is a wrapper to gcc that translate armcc flags ie ARM7TDMI to -mcpu=arm7tdmi ...
ie the opposite of :
http://infocenter.ar...c/CHDDJHCH.html
Is there a free compiler to build OX000-BU-00010-r1p0-00bet0.tgz ?
Edit:
.s files are not supported by gcc yet :
http://forums.arm.co...6579#entry36579
and linking the armcc lib w/ ld is not working on that platform :
http://www.anddev.org/ndk-problems-f56/crash-ld-terminated-with-signal-11-t54593.html
But, I managed to build C files using gcc ..
If someone care I may to publish a debian patch, am i granted to distribute a copy to OX000-BU-00010-r1p0-00bet0.tgz ?
Also a COPYING file would be welcome for upcoming releases...
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Edit:
Cancel
Vote up
0
Vote down
Cancel
