Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Problem in generating position independent code with out TEXTREL
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Darisi V SATISH BABU
over 13 years ago
Note: This was originally posted on 12th August 2010 at
http://forums.arm.com
Hi Experts,
Issue:Not able to remove TEXTREL from our static library generated with --apcs /fpic option using armcc(RVCT 4.0 build 771 tool chain)
Description:
We compiled our codebase(some modules with handwritten assembly) using armcc(RVCT 4.0 build 771 tool chain) to get static libraries, and then these are used by gstreamer module which further compiles using the above generated libraries with wrappers using GCC tool chain and creates shared objects(.so).
Even though we use equivalent --apcs /fpic compile time option during static library creation to remove position independent code, the TEXTREL are not going from library.
When we disable the (handwritten assembly) in the above mentioned codebase, TEXTRELs go away.
As there are lot of handwritten ARM assembly functions,its difficult to enable one by one and compile and check.
So,Experts please throw some light on this issue.
Thanks In Advance,
satish
over 13 years ago
Note: This was originally posted on 3rd January 2011 at
Hi Experts,
I was able te resolve the TEXTREL issues(by avoiding functions calls using LDR and DCD/DCW...for data) in some code bases with the solutions provided by Scott & others............
Now i am working on some other code base where i am facing TEXTREL issues due to access of tables.
Please go through the below mentioned sample program which replicates my issues.........
sample program:
short int table[30] = {1,2,3,4,5,.......,30};
void foo {
__asm {
LDR r4,=table
(with --apcs /fpic option) - When i use C code of the above corrsponding assembly then compiler is taking care of TEXTREL issue(able to remove TEXTREL by using RELOC),but when i access the table using embedded assembly, assembler is not able to generate the TEXTREL free code.Please throw some light on this issue..........
Thanks In Advance,
satish
Cancel
Vote up
0
Vote down
Cancel
over 13 years ago
Hi Experts,
sample program:
void foo {
__asm {
LDR r4,=table
Thanks In Advance,
satish
Cancel
Vote up
0
Vote down
Cancel
