I am running the "CMSIS-RTOS2 Blinky (uVision Simulator)" example for Cortex-M4 in Arm Dev Studio on Windows. I am using ARM C/C++ Compiler 6.
The example runs ok. I have now added several C++ files to it. These compile and link ok, but when I increase the number of objects ( instantiated by new() ) on the heap the program either crashes or raises a bad_alloc exception.
I have tried increasing the heap allocation in the scatter file but that seems to make no difference. I am therefore wondering whether I am increasing it correctly or whether there is some startup requirement for C++ that I am unaware of.
My scatter file is:
CMSIS-RTOS2 Blinky (uVision Simulator)_Simulation\RTE\Device\ARMCM4\ARMCM4_ac6.sct
and the contents are:
#! armclang -E --target=arm-arm-none-eabi -mcpu=cortex-m4 -xc ; command above MUST be in first line (no comment above!) /* ;-------- <<< Use Configuration Wizard in Context Menu >>> ------------------- */ /*--------------------- Flash Configuration ---------------------------------- ; <h> Flash Configuration ; <o0> Flash Base Address <0x0-0xFFFFFFFF:8> ; <o1> Flash Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> *----------------------------------------------------------------------------*/ #define __ROM_BASE 0x00000000 #define __ROM_SIZE 0x00080000 /*--------------------- Embedded RAM Configuration --------------------------- ; <h> RAM Configuration ; <o0> RAM Base Address <0x0-0xFFFFFFFF:8> ; <o1> RAM Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> *----------------------------------------------------------------------------*/ #define __RAM_BASE 0x20000000 #define __RAM_SIZE 0x00040000 /*--------------------- Stack / Heap Configuration --------------------------- ; <h> Stack / Heap Configuration ; <o0> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8> ; <o1> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> ; </h> *----------------------------------------------------------------------------*/ #define __STACK_SIZE 0x00000400 #define __HEAP_SIZE 0x0000A000 /* ;------------- <<< end of configuration section >>> --------------------------- */ /*---------------------------------------------------------------------------- User Stack & Heap boundary definition *----------------------------------------------------------------------------*/ #define __STACK_TOP (__RAM_BASE + __RAM_SIZE) /* starts at end of RAM */ #define __HEAP_BASE (AlignExpr(+0, 8)) /* starts after RW_RAM section, 8 byte aligned */ /*---------------------------------------------------------------------------- Scatter File Definitions definition *----------------------------------------------------------------------------*/ #define __RO_BASE __ROM_BASE #define __RO_SIZE __ROM_SIZE #define __RW_BASE __RAM_BASE #define __RW_SIZE (__RAM_SIZE - __STACK_SIZE - __HEAP_SIZE) LR_ROM __RO_BASE __RO_SIZE { ; load region size_region ER_ROM __RO_BASE __RO_SIZE { ; load address = execution address *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) .ANY (+XO) } RW_RAM __RW_BASE __RW_SIZE { ; RW data .ANY (+RW +ZI) } #if __HEAP_SIZE > 0 ARM_LIB_HEAP __HEAP_BASE EMPTY __HEAP_SIZE { ; Reserve empty region for heap } #endif ARM_LIB_STACK __STACK_TOP EMPTY -__STACK_SIZE { ; Reserve empty region for stack } }
so the heap allocation should be 0xA000.
The linker command is:
armlink.exe --entry=Reset_Handler --scatter="C:\prototypes\CMSIS-RTOS2 Blinky (uVision Simulator)_Simulation/RTE/Device/ARMCM4/ARMCM4_ac6.sct" --info=sizes --strict -o "CMSIS-RTOS2 Blinky (uVision Simulator)_Simulation.axf" ./src/Elysion.o ./src/ElysionSectionList.o ./RTE/Device/ARMCM4/startup_ARMCM4.o ./RTE/Device/ARMCM4/system_ARMCM4.o ./RTE/Compiler/EventRecorder.o ./RTE/CMSIS/RTX_Config.o ./RTE/CMSIS/irq_armv7m.o ./RTE/CMSIS/os_systick.o ./RTE/CMSIS/rtx_delay.o ./RTE/CMSIS/rtx_evflags.o ./RTE/CMSIS/rtx_evr.o ./RTE/CMSIS/rtx_kernel.o ./RTE/CMSIS/rtx_lib.o ./RTE/CMSIS/rtx_memory.o ./RTE/CMSIS/rtx_mempool.o ./RTE/CMSIS/rtx_msgqueue.o ./RTE/CMSIS/rtx_mutex.o ./RTE/CMSIS/rtx_semaphore.o ./RTE/CMSIS/rtx_system.o ./RTE/CMSIS/rtx_thread.o ./RTE/CMSIS/rtx_timer.o ./Blinky.o ./ElysionMain.o
so, correct scatter code and, hopefully, correct startup files are used.
My C++ compiler options are:
armclang.exe --target=arm-arm-none-eabi -I"C:\prototypes\CMSIS-RTOS2 Blinky (uVision Simulator)_Simulation/src" -xc++ -fexceptions -O0 -g -DARMCM4 -D_RTE_ -mcpu=cortex-m4 -mfpu=none -mlittle-endian -Oz -g -Wall -fshort-enums -fshort-wchar -ffunction-sections -fno-rtti -MD -MP -c -o "ElysionMain.o" "../ElysionMain.cpp"
Can you please suggest what may be wrong?
Thanks Ronan, I will give those a try.Best regards,
David
Hi Ronan
Your answer led me to the fix. The trace showed that osRtxErrorStackOverflow was occurring. Increasing the thread's stack size fixed the problem. Thanks very much for your help.
Best regards
