Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
ARM CORTEX A8 : use of fpack-struct compiler directive
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
shashikumar MS
over 13 years ago
Note: This was originally posted on 27th May 2009 at
http://forums.arm.com
I am compiling an application with arm linux gcc version 4.2.3 (Sourcery G++ Lite 2008q1-126) with the compiler directive's.
I want to optimize this application for the ARM and I am not suppose to use DSP.
[font="Courier New"]
arm-linux-gcc ../Src/*.c ../Src/SimdFunctions.s ../Src/getRectSubPix.s -DOPT_WIN_SIZE -DENABLE_SIMD_GETRECTSUBPIX -DUSE_SIMD -DUSE_SIMD_DAVID -I ../Inc -mcpu=cortex-a8 -mfpu=neon -Wa,-mfpu=neon -mfloat-abi=softfp -o ../Obj/opt_blink.out -O3 -fpack-struct -freorder-blocks-and-partition -lm -lc -lgcc -ftree-vectorize[/font]
after compilation total number of lines of assembly code generated is 35563.
If i remove the compiler directive -fpack-struct the total number of lines of assembly code is 22354.
I checked this by writing a small C program which updates the structure that consists of 3 integer elements. consider if i want to write 55, 66, 77 to these three elements then
with -fpack-sturct directive the program uses byte store to store 55, 66, 77 and then fills the remaining bytes with zeros which generates around 20 lines of assembly code
whereas without -fpack-sturct it writes directly to the location and the assembly generated is is of about 5 lines.
Also help me in any compilation directives to be given to optimize even more.
thanks and regards
Shashi
shashi.ms@samsung.com
Peter Harris
over 13 years ago
Packing data structures is one of those interesting areas of C which is really "interesting" on ARM, if only because the history of unaligned access support is so fragmented.
The GCC compiler assumes that unaligned access is not supported by default - so if you tell it all structures are packed it replaces neat word / halfword loads with individual byte loads and then assembles the result in registers. Consequently the amount of assembler you need goes up quite a lot.
I'm not aware of support in GCC for generating unaligned loads.
In general packing structures generates sub-optimal code - do you need to pack all of your structures?
Cancel
Vote up
0
Vote down
Cancel
shashikumar MS
over 13 years ago
Thanks for the reply at the earliest.
I need not pack as most of the structures are defined in such a way that holes are not left in between.
we have done lots of c optimization in this application. are there any new compilation directives which can give more optimization for speed ?
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
It may be worth seeing if ARM's RealView compiler can offer the performance you are after.
A free evaluation can be requested from [url="
http://www.arm.com/phpscripts/rvds_eval.php
http://www.arm.com/phpscripts/rvds_eval.php[/url]
hth
s.
Cancel
Vote up
0
Vote down
Cancel
