Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Realview aligning variables
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Johan Moraal
over 13 years ago
Note: This was originally posted on 22nd August 2011 at
http://forums.arm.com
Hi
In Keil RealView is there some compiler or linker command switch that will ensure that all declared variables will be aligned to a 32bit boundary?
Edit: I'm using the Keil MDK toolchain, I'm not sure if this is the same as Realview. I've come across --min_array_alignment=4. I don't think its applicable to non array types. I want all types to be aligned
Martin Weidmann
over 13 years ago
Out of interest, why?
I've not used the MDK much, but I'd guess it's similar to RVDS... In which case you could try:
http://infocenter.arm.com/help/topic/com.arm.doc.dui0491c/Cacjcjce.html
Cancel
Vote up
0
Vote down
Cancel
Johan Moraal
over 13 years ago
I saw that one as well. But never mind I figured out that alignment is not my problem
Cancel
Vote up
0
Vote down
Cancel
