Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Keil RTX and bootloading
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Johan Moraal
over 13 years ago
Note: This was originally posted on 25th January 2011 at
http://forums.arm.com
Hi all.
I've recently written a secondary bootloader for NXP LPC17xx devices. The design is relatively simple: All our products have embedded serial flash connected with an SPI bus to the micro. The user application is responsible to load a binary image onto the serial flash. When the bootloader starts, it checks the serial flash for a binary image. If one is not found, it jumps to the user application. If one is found, it verifies the integrity of the image by doing a CRC check. If the check passes it begins to update the LPC's flash from the binary image on the serial flash.
I've confirmed that the bootloader application is working properly. Firstly I checked the LPC's flash with a ULINK Pro and made sure the bootloader is not accidentally overridden. Then I uploaded a small application that reads and verifies a large chunk of flash and blinks a led. All these tests succeeded and I'm confident my bootloader works properly.
The problem arises when I try to upload an application which uses the Keil RL-ARM real time OS. When I upload this type of application, nothing happens. I traced the problem with a ULINK and I found that the trace stops at SVC_Handler in startup_LPC17xx.s.
All our RL-ARM based applications run in privileged mode. I know the RTOS uses SVC to access hardware etc in privileged mode.
Is there something I should do in the bootloader in order to support RL apps?
Jean Fernandes
over 13 years ago
Note: This was originally posted on 21st August 2011 at
Johan
I have a booloader running on 0x00000000 and another application starting 0x00002000, where the first read the external
flash and copy the firmware upgrade to 0x00002000 and jump the pc for it.
So What do I need modify on
startup_lpc17xx.s
core_cm3.h
system_lpc17xx.c
lpc17xx.h
In order to :
- Use the 0x00002000 application on normal and debug mode, avoiding undesired writes on bootloader region.
- Remap all vector address to run the application normally.
Should you explain, what the correct order of code execution before the PC go to the main ?
Regards.
Jean Fernandes
Cancel
Vote up
0
Vote down
Cancel
Jean Fernandes
over 13 years ago
Johan
startup_lpc17xx.s
core_cm3.h
system_lpc17xx.c
lpc17xx.h
In order to :
Regards.
Jean Fernandes
Cancel
Vote up
0
Vote down
Cancel
