Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Debugging a Usage Fault for an unaligned memory access
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
gamze mazlum
over 13 years ago
Note: This was originally posted on 4th July 2013 at
http://forums.arm.com
I am experiencing a hard fault in Cortex M3.
After reading some topics in forums and blogs, I added the following code for analyze the problem.
void hard_fault_handler_c(unsigned int * hardfault_args)
unsigned int stacked_r0;
unsigned int stacked_r1;
unsigned int stacked_r2;
unsigned int stacked_r3;
unsigned int stacked_r12;
unsigned int stacked_lr;
unsigned int stacked_pc;
unsigned int stacked_psr;
stacked_r0 = ((unsigned long) hardfault_args[0]);
stacked_r1 = ((unsigned long) hardfault_args[1]);
stacked_r2 = ((unsigned long) hardfault_args[2]);
stacked_r3 = ((unsigned long) hardfault_args[3]);
stacked_r12 = ((unsigned long) hardfault_args[4]);
stacked_lr = ((unsigned long) hardfault_args[5]);
stacked_pc = ((unsigned long) hardfault_args[6]);
stacked_psr = ((unsigned long) hardfault_args[7]);
printf ("[Hard fault handler]\n");
printf ("R0 = %x\n", stacked_r0);
printf ("R1 = %x\n", stacked_r1);
printf ("R2 = %x\n", stacked_r2);
printf ("R3 = %x\n", stacked_r3);
printf ("R12 = %x\n", stacked_r12);
printf ("LR = %x\n", stacked_lr);
printf ("PC = %x\n", stacked_pc);
printf ("PSR = %x\n", stacked_psr);
printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
while(1);
__asm void Hard_Fault_Handler(void)
TST LR, #4
ITE EQ
MRSEQ R0, MSP
MRSNE R0, PSP
B hard_fault_handler_c
However, I am still not able to figure out which is causing the hard fault.
I need a lot of help, I will be very grateful. I can provide more information if needed.
In attachments, there are register's and fault report's print screens.
Thank you
Regards,
gamze mazlum
over 13 years ago
In addition, I'm using Keil.
Cancel
Vote up
0
Vote down
Cancel
Simon Craske
over 13 years ago
Pelefek,
Try opening a memory window and looking at the 32-bit word at location 0x20007A00 (The address shown by PSP + 24). This value should be the address of the instruction that caused the fault (or the one immediately after it).
hth
s.
Cancel
Vote up
0
Vote down
Cancel
