Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Build error with DS500-BN-00001-r5p0-13rel0
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Sreenath P V
over 13 years ago
Note: This was originally posted on 10th July 2013 at
http://forums.arm.com
I have a fedora pc and DS-5 version " DS500-BN-00001-r5p0-13rel0.tgz " installed in it. But While i tried to build the application error occurs as shown below
/usr/local/DS-5/sw/gcc/bin/../lib/gcc/arm-linux-gnueabihf/4.7.1/../../../../arm-linux-gnueabihf/bin/ld: error: sample-app uses VFP register arguments, CMakeFiles/sample-app.dir/sample-app.c.o does not
/usr/local/DS-5/sw/gcc/bin/../lib/gcc/arm-linux-gnueabihf/4.7.1/../../../../arm-linux-gnueabihf/bin/ld: failed to merge target specific data of file CMakeFiles/sample-app.dir/[size=2]sample-[/size][size=2]app.c.o[/size]
[size=2]
[/size]
[size=2]I use these options while building application.. [/size][size=2]"[/size][size=2] -mcpu=cortex-a8 -mfpu=neon -mfloat-abi=softfp -funsafe-math-optimizations -ftree-vectorize [/size][size=2]-fPIC -fsigned-char "[/size]
[size=2]
[/size]
[size=2]Anyone have idea about this..[/size]
Martin Weidmann
over 13 years ago
Not a GCC expert, but it looks like its the ABI your using.
In your build command you setting the floating point ABI as soft (pass floating point arguments in integer registers). But the error message from the linker suggests that what you're linking against is built for hard float (pass floating point arguments in VFP registers). You can't mix objects with different ABIs (at least not if you want them to work).
Cancel
Vote up
0
Vote down
Cancel
Sreenath P V
over 13 years ago
Thanks for reply.. I changd my compile opitions as below , Now the code builds sucessfully. But in my hardware ( Panda board ) the application is not running.
-march=armv7-a -mfpu=vfp -mfloat-abi=hard -funsafe-math-optimizations -ftree-vectorize -mcpu=cortex-a8
Other details
Buld machine : Fedora 14, DS5 release 13
Running Hardware : panda board with linux
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
What distribution is your Pandaboard running? (Maybe 'cat /etc/lsb-release')
You need it to have an 'hf' ABI root filesystem to run apps built with -mfloat-abi=hard
If it has 'hf' ABI it should have /lib/ld-linux-armhf.so.3 and /lib/arm-linux-gnueabihf/
If it has softfp ABI it should have /lib/ld-linux.so.3
By the way:
- the latest version of DS-5 is v5.15
- Panda uses Cortex-A9 not Cortex-A8. (Building for Cortex-A8 shouldn't cause a failure, but might be sub-optimal.)
Cancel
Vote up
0
Vote down
Cancel
Sreenath P V
over 13 years ago
Note: This was originally posted on 11th July 2013 at
thanks Scott,
We were using old version of angstrom linux in panda board, that may be the cause of this error. Actually my target to port application in Cortex A8 platform thats why i choose cpu cortex-a8.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
The Linaro Ubuntu image for Pandaboard might be an alternative:
http://releases.lina...06/ubuntu/panda
Cancel
Vote up
0
Vote down
Cancel
