Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
DS-5 bsp compiler 5 license
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
dream willy
over 13 years ago
Note: This was originally posted on 1st July 2013 at
http://forums.arm.com
Hi All,
I just applied for a DS-5 Eval License to compile my code on ARM.
I get the following error and am stuck. Incidentally, my fellow developer also has this tool installed with the same Eval license which he had applied over 3 weeks ago and it seems to compile just fine on his System. Has there been any changes to the tool now that some features have been removed henceforth??
Here is my error:
ARM C/C++ Compiler, 5.03 [Build 76]
Error: C9932E: Cannot obtain license for Compiler (feature compiler5) with license version >= 5.0201305
No such feature exists.
Feature: compiler5
License path: /opt/DS-5/license.dat:/home/tbase/.ds-5/licenses/DS-5 Professional (30-day Evaluation).lic:
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".
Cannot obtain license for Compiler (feature bsp_compiler5) with license version >= 5.0201305
Feature: bsp_compiler5
Thanks a lot.
Note: I applied for the license via Eclipse ARM License Manager. My DS-5 is installed in the /opt/DS-5 directory on a linux Ubuntu system.
Regds,
Willy
Scott Douglass
over 13 years ago
Note: This was originally posted on 2nd July 2013 at
So, let me make sure I understand; are all of these true?
- you're building in Eclipse on a Linux host
- the example projects build fine
- your project fails to build with the licensing error message given earlier
Old question: Is there a toolkit selected in the popup menu at the bottom [of the ARM License Manager dialog]?
New questions
Can you copy and post the information from the Diagnostics pane of the ARM License Manager dialog?
In C/C++ Build > Environment, is "Append variables to native environment" selected or is "Replace native environment with specified one" selected? If "Replace ..." is selected you'll need to add an ARM_DS_TOOLKIT_KEY with "ds5eval".
Please look in the Properties > C/C++ Build of your project that doesn't work:
What is the Builder type?
Is "GenerateMakefiles automatically" checked?
It would be useful to know the full armcc command line and, if you are not using automatically generated makefiles, to modify the Makefile to dump out the environment ('env') so I can see PATH and the license management variables.
The eval mechanism in v5.15 and recent eval licenses has changed, but the eval is meant to be fully functional.
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
New questions
Cancel
Vote up
0
Vote down
Cancel
