Site
Search
User
Site
Search
User
Forums
Arm Development Studio forum
Simulator Based C project (Non OS)
Jump...
Cancel
Locked
Locked
Replies
Subscribers
119 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
Bhooshan Iyer
over 13 years ago
Note: This was originally posted on 11th June 2013 at
http://forums.arm.com
I am trying to create a couple of trivial C & ARM 7/9 assembly example projects on DS-5 to run using Simulation mode like I used to be able to do in RVDS without having to connect the host pc to a hardware. Nor do I want to involve linux for these trivial examples. To that extent these are bare-metal examples but only that I wont be connecting to any hardware. I think in Real View it used to be called a connection to RVISS or something like that. I used to be able to teh choose the ARM processor I was targeting inside that. I assume such programming is with DS-5 too. When I look into debug configuration, I dont see an explicit ISS or simulator sounding name as target.
Can someone point me along the right direction for creating a clean, simple, simulator based C and Assembly projects in DS-5 professional edition?
Thanks.
Scott Douglass
over 13 years ago
Note: This was originally posted on 13th June 2013 at
I'm glad you've got it working. If you could explain more about what was initially confusing that would be helpful. By "redundancy" do you mean the various ways to get to the Debug Configuration dialog or something else? (Sorry, I pointed you to App Console instead of Target Console. The App Console is the stdio place when doing Linux app debug.)
You can build for ARM7TDMI and run the code on the Cortex-A9 model, but there's no ARM7 model supplied. (Although big-endian might be a problem; I'm not sure if Cortex-A9 supports BE32.)
Cancel
Vote up
0
Vote down
Cancel
Scott Douglass
over 13 years ago
Cancel
Vote up
0
Vote down
Cancel
